Advancing the timing
Old Nov 4, 2003 | 08:07 PM
Gr8ride's Avatar
Gr8ride
Howdy,
If I am standing in front of the truck which way do I turn the injection pump to advance it? (counter clockwise or clockwise)
I was pulling 8000 pounds up a long somewhat steep hill and I didn't see any black smoke at all. I should see a little shouldn't I?
Thanks,
Gr8ride
Old Nov 5, 2003 | 09:56 AM
lgspitler's Avatar
lgspitler
To advance the timing turn the injection pump toward the passenger side of the truck, or counter clockwise as viewed from the front. In my experience, which is limited, the lack of black smoke is probably more related to the fuel volume than injection timing. That is adjusted through a small window on the passenger side of the pump with an allen wrench. Clockwise increases fuel volume and counter clockwise decreases it. I would go in 1/8 or 1/4 turn increments and try it. Be careful. Too much fuel and black smoke and the temperature will increase when you pull hard. I saw a detailed post of how to set the fuel volume on here somewhere. I believe you have to put a mark on the harmonic balancer in the 1:00 or 1:30 position to have the allen screw accessible. Good luck!
Old Nov 5, 2003 | 07:46 PM
Fordhog's Avatar
Fordhog
If you wan't more fuel turn your screw in one flat of the allen head screw, 1 and a half if you like to fog mosquitos, any more is just throwing fuel out the tailpipe. lgspitler is right on the timing, it has nothing to do with smoke, he's also right on the direction to turn the pump to advance it. If your truck has a healthy diesel sounding "crack" to it I would't worry about the timing.
Old Nov 6, 2003 | 09:27 AM
lgspitler's Avatar
lgspitler
If you do play with the timing the Ford spec is +or- .030 for the timing mark on the pump and housing it mounts to so we are talking very small adjustments. A slight timing advance may improve throttle response and as Fordhog said make the injectors rattle a little louder.
Old Nov 8, 2003 | 10:29 PM
banshee 350 longrod's Avatar
banshee 350 longrod
you should have a pyro before adjusting your fuel so you do not melt your motor.
Old Nov 9, 2003 | 08:11 PM
Gr8ride's Avatar
Gr8ride
Howdy,
Now that I know adjusting the timing isn't going to do what I want, I think I will hold off on increasing the fuel until I get a pyro like banshee suggested.
What brand pyro gauge do you guys recommend?
Thanks for the info guys.
Gr8ride
Old Nov 22, 2003 | 07:56 PM
Go Navy-Beat Army's Avatar
Go Navy-Beat Army
And where do you put the sensor or probe for the pyrometer?
Old Dec 1, 2003 | 10:50 AM
mattydiesel's Avatar
mattydiesel
what if you are seeing constant white smoke and to smell it it smells like fuel
would this be the injector timing or the fuel adjustment on the side?
it is a 94 7.3 idi turbo
thanks
Old Dec 2, 2003 | 12:43 AM
Dave Sponaugle's Avatar
Dave Sponaugle
mattydiesel
If the engine is at operating temp the white smoke is oil from somewhere. Sounds like a turbo oil seal to me...or some other seal or ring broke or hole in the piston or... If it is not up to operatine temp then you have glow plug problems with the after glow untill the engine warms up.
Old Dec 2, 2003 | 12:47 AM
Dave Sponaugle
Gr8ride,
To much black smoke will wash your rings out.....early rebuild to re-ring. One flat is probably more than enough.
Old Dec 2, 2003 | 12:53 AM
Dave Sponaugle
Go navy,
In the exhaust manifold is the best place, in my opinion, close to the place making the heat so you get a good, early reading of what is coming out of the cylinders. Then keep that down to about 1150....1200 tops
Old Dec 2, 2003 | 08:28 AM
mattydiesel
i had it at the middle of normal and when it is idleing its ok but as soon as you hit the gas the white smoke starts, you could fog mosqutioes, lol
Old Dec 2, 2003 | 10:32 AM
Spectramac's Avatar
Spectramac
matty, how does it run when the smoke comes in? Is it dropping cylinders?
Old Dec 2, 2003 | 10:52 AM
mattydiesel
yes you can feel it dropping a cylinder, the smoke, white, does smell like fuel
at idle its ok, very little smoke as soon as you hit the gas its bad
Old Dec 3, 2003 | 11:33 PM
Spectramac's Avatar
Spectramac
I'd try to find out which cylinder(s) is(are) the problem by cracking loose the injectors while it's smoking and see if you can at least make the smoke go away. If you find one, pull it out and see if the tip is bad. They should have a small point in the middle. If you just see a small hole, the tip is gone. That would let it get un atomized fuel, which won't burn. If it looks ok, get it pop tested anyway, maybe the problem's inside. There's my 2 cents.
Gr8ride
18
Apr 19, 2007 08:39 PM
Gr8ride
Aug 23, 2005 04:09 PM
Gr8ride
19
Mar 23, 2004 11:14 AM
Gr8ride
May 20, 2003 05:23 PM
Gr8ride
Apr 20, 2003 09:30 AM
