1978 - 1996 Big Bronco
Engine Oil Saturating Filter
Old Feb 15, 2002 | 10:14 AM
FS88Bronco's Avatar
FS88Bronco
Post Engine Oil Saturating Filter
Own an '88 Bronco XLT 5.8L with 133K ... runs good and doesn't require adding oil between changes at around 2K. Problem is the small crankcase breather [paper fiber] filter, located below the primary air filter becomes saturated with engine oil after about 1,500 miles. Have taken off both valve covers and cleaned out gunk accumulations ... also made sure oil returns holes were clear. Still have problem, but to a lesser degree. Does anyone know what causes this problem and ways to correct it ... thanks, John
Old Feb 15, 2002 | 02:34 PM
SBV1's Avatar
SBV1
When mine did that it was blowby from worn rings creating excessive crancase pressure. I could clean it out, run it around for a few hundred miles and it would be saturated again.
I suggest a compression check. How many miles on this engine?
Old Feb 15, 2002 | 08:52 PM
Franklin2's Avatar
Franklin2
Make sure your pcv valve is working and sucking air like it should. After this, the previous poster is probably right. But if you don't worry about stuff like this, the engine will probably keep running a long time. We had another post in another forum where we were talking about how bad our engines got, and they still ran ok. That's when I mentioned the blowby in one of my cars was so bad, I took the hose off the aircleaner and hooked an old length of heater hose to it and ran it down underneath the truck to get rid of the oil smoke.
Old Feb 16, 2002 | 03:01 PM
JBronco's Avatar
JBronco
I had this problem on a Ranger. Turned out to be a cracked piston ring.
Old Feb 16, 2002 | 03:03 PM
JBronco's Avatar
JBronco
PS - Hey Franklin us bikers really appreciated that...
Old Feb 17, 2002 | 11:10 AM
Franklin2's Avatar
Franklin2
Do they make street helmets with tear-away strips?:7
Old Feb 17, 2002 | 11:31 AM
JBronco's Avatar
JBronco
Helmet? What's that?
Old Feb 17, 2002 | 01:55 PM
Bob_VT's Avatar
Bob_VT
DavenTn
Dec 6, 2016 10:58 AM
kelsodiesel
Jun 1, 2012 12:14 AM
diggerrigger
Jan 20, 2010 04:34 AM
bullofthewoods
Mar 14, 2005 11:30 PM
Deadblow
Apr 21, 2002 09:17 PM
