Bronco II Ford Bronco II
Gauges
Old Apr 4, 2007 | 03:23 PM
Canadianice's Avatar
Canadianice
Gauges
I was wondering if I am able to switch the gauges off a newer Bronco II to my 84. I am interested switching in a tachometer in place of my simple amp, fuel, temp light, oil light. Is this switch possible?
Old Apr 4, 2007 | 06:08 PM
kernel-panic's Avatar
kernel-panic
You'd have to take a look at the wiring diagrams and see if everything is the same as well as check your vehicle to see if the wiring is the same as the donor vehicle and that the wiring for the tach is present.
Old Apr 5, 2007 | 10:46 AM
todd koebel's Avatar
todd koebel
If you go to www.therangerstation.com, they have an article about switching the dash from an 89-94 (also from explorers and rangers) to an 83-89. Might be too much work, but it will get you the tach you want.
Old Apr 5, 2007 | 12:12 PM
kernel-panic
Which is the dash swap I'd love to do, eventually. Especially if I get the XLT/Eddie Bauer cluster with all 4 gauges, tach, and speedo.
vwfreak
Nov 6, 2013 06:21 PM
Bossdrum
Sep 11, 2012 09:52 PM
sonsila
21
Aug 31, 2009 05:59 AM
ghunt
Electrical Systems/Wiring
Jan 31, 2009 09:54 AM
joe_13894
Aug 1, 2008 11:12 AM
