Sponsored by: Auxito
fuel filter replacement = happy driver!
Old Apr 6, 2007 | 07:09 AM
  #31
ncranchero's Avatar
ncranchero
Here are your 3 most popular tool choices.
Old Apr 6, 2007 | 08:05 PM
  #32
streethealer's Avatar
streethealer
Mine is the second one in the pics above. You just wrap the scissors around the line, press it into the spring loaded fitting and slide the line off...
Old Apr 6, 2007 | 09:46 PM
  #33
pat2724's Avatar
pat2724
Thanks I am changing it on Saturday.
Old Apr 7, 2007 | 10:23 AM
  #34
pat2724's Avatar
pat2724
Done it runs great. It had original mc filter in it . Pretty easy unplug 19 fuse for feul pump. releave pressure on fuel rail. Undo clips and slide grey 5/16 tool on filter side of line. Do both sides and install new filter and reverse process. Thanks guys for your help.
Steve
Old Apr 7, 2007 | 07:12 PM
  #35
eveready77's Avatar
eveready77
glad it worked out for ya. Now see if you get any better fuel economy. So far mine seems to be doing better.
Old Apr 7, 2007 | 07:24 PM
  #36
ncranchero's Avatar
ncranchero
Success is always good to hear. The worst part of changing fuel filters is the occasional stream of gas that makes it's way to your armpit.
Old Apr 22, 2007 | 09:36 PM
  #37
eveready77's Avatar
eveready77
Well it has been almost two tanks of gas and I have a pretty good idea on my fuel numbers. The overall average these past two tanks has been 14.5. This is mostly in-town driveing while makeing an effort to keep it below 2000 rpm, and keeping my takeoffs from redlights maturely. Overall i'm pleased. I gained around around 1mpg in town so hopefully it will give up a little more on the hwy. The truck haveing its pep back in its step is rewarding enough anyway. Thanks for the input y'all! -David
Old Apr 23, 2007 | 05:52 AM
  #38
pat2724's Avatar
pat2724
I would have to agree with you my truck runs great since fuel filter replacement . It has more power and a increase on milage.
Old Apr 23, 2007 | 07:07 PM
  #39
Lance1601's Avatar
Lance1601
Mines doing noticeably better since I changed my fuel filter. Oh BTW I bought the metal fuel line disconnect tool from Auto-zone and it didn't fit. I seem to remember the metal one from Advance years ago not fitting either. I bought the plastic one and it fit fine.
Old Apr 23, 2007 | 11:42 PM
  #40
Beanpod's Avatar
Beanpod
Armed with knowledge from this thread, I changed my fuel filter last week. Bought the scissors type tool from AZ. A bit difficult disconnecting. In hindsight, looking at the mechanics of the spider type connection, I believe it would hve been easier if I had pushed the connector towards the filter while inserting the tool before pulling loose. I was pulling the whole time and probably added resistance to the disconnect. Performance difference was not greatly noticable, but filter was original with 56K miles, so it was about time for a change.
Jymmm
21
Apr 3, 2019 12:52 AM
lvin4jc
29
Jan 5, 2017 01:04 PM
SunBum
22
Aug 12, 2016 06:02 AM
Gryphon1962m
May 18, 2016 02:03 PM
Motorhead26
32
Jan 7, 2008 07:49 PM
