Let me start out by saying this DP Tuner chip i just installed in my 2000 f250 is out of this world. I love it. I had a couple of questions to ask. I am due for emissions and dont know what program i shold put it in. Stock or 80 economy?? Also is there any other recommendations i should do to the truck to keep it balanced as in fuel and not killing my engine now that i have this new awsome chip??
I have a 2000 6" lifted psd, 35" banks power pack system(includes intake,4" exhaust, banks turbine w/ housing, big head waste gate, banks intercooler), with DP Tuner chip, 120 race, 140 aggressive, 80 econo., hi idle, and stock.
Well I believe Jody removes the rev limiter in his tunes so if they do the rev test (hold at WOT) you could over rev. Stock would be the safest setting but I think Pocket did his test in one of the tow tunes just to see.
Yeah I was tested last April when I still had the stock exhaust and stock turbo. Ran in the 40hp tow setting and passed with an 8% opacity. Failure here is 35%, so I was well under. No idea what it would do in the 80 econo, but I know that setting smokes a bit more in higher altitude. Something to think about if you do live at an elevation.
If I were you, I'd just run it in the stock setting.
FWIW-Jody does not remove the rev limiter, but only raises the rev limtier slightly according to what you want and the set up they have.( ie.pullers and racers).
Diane
__________________ Jody & Diane Tipton- DP-Tuner® FTE Legacy Sponsors since 2006 Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost, Get Tuned!828-221-0076 ext. 802 Become our Facebook Fan
This is paticularly why Jody likes to put a stock tune on the chip. You have it. Use the stock tune for emmisions testing. Unless you have bigger injectors then he can write you an emmisions friendly tune.
Diane
