Front Hub Locknut Torque
Old Apr 2, 2007 | 07:12 PM
t4kne's Avatar
t4kne
Could someone tell me what I should torque the front hub locknuts to on a 1993 F150 (4X4)? Do I torque both locknuts the same? Thanks for your help.
Tim
Old Apr 2, 2007 | 07:43 PM
andym's Avatar
andym
10-15 ft-lbs is about all you need. Enough to seat the bearings fully. The outer one should be cranked down pretty tight. 50 lb-ft or so.
Old Apr 2, 2007 | 08:00 PM
Bruce R Leech's Avatar
Bruce R Leech
by the other one I think he means the outer or lock nut.
Old Apr 3, 2007 | 06:48 AM
albung's Avatar
albung
mine has only one nut ???? on each side am i missing one????
Old Apr 3, 2007 | 07:35 AM
t4kne's Avatar
t4kne
Thanks for the info.
Albung: I have two locking nuts for each side and in between them is a large washer with lots of small holes in it. These small holes line up with a single pin on the inner locknut. It has manual locking hubs, does yours have auto locking? I'm guessing that might be the difference.
Old Apr 3, 2007 | 08:54 AM
fbama73's Avatar
fbama73
^ tk4ne, it sounds like your truck has been converted from auto hubs to manuals, because the setup you just described is identical to the conversion kit that i bought when converting mine to manuals.
The 10-15 ft-pound spec is not for the inner nut, which actually sets the preload on your wheel bearings. The outer nut gets a lot more torque to lock the assembly in place. Along the lines of 160-210 ft pounds
Here's the installation instructions from Warn
http://warn.iwebcat.com/imgVD/WAR/32722A2-pn32720.pdf
Old Apr 3, 2007 | 05:00 PM
albung's Avatar
albung
got flange hubs that the lug nuts hold on with the tire is this why????? im thinkin in missing something now
Sevrock
Jul 13, 2016 10:39 PM
AKHunter93
19
May 31, 2015 09:56 AM
79F-350
Apr 10, 2010 06:18 PM
tom2131968
1978 - 1996 Big Bronco
Aug 20, 2006 09:56 AM
newfordguy88
Nov 14, 2005 08:42 AM
