TX2 winch wiring
Old Apr 1, 2007 | 06:53 PM
redlineps's Avatar
redlineps
TX2 winch wiring
I was given a TX2 winch and was told it worked. In the configuration it was given to me, I can't figure the wiring. It has 2 positive leads and 2 negative leads and the wires from the controler box have been cut. I have a nice Ramsey on my truck. Looking to put the TX2 on my car hauler. Anyone with wiring information would be appreciated. Thanks...Moe
Old Apr 1, 2007 | 08:11 PM
Franklin2's Avatar
Franklin2
I don't know if I went down a rabbit trail or not, but I found out your winch may have been made by a company called Tensen. And apparently now they are called Megawinch. I found a link here.
http://www.tempserver.net/megawinch/winch.htm
Do a little bit of tracing on your wires. Are they all large and all 4 go to the motor? If so, from the description I read, they use a series wound motor. If this is true on yours, you should be able to take a ohmmeter, and get continuity between 2 of the wires, and continuity on the other two. If this checks out, then mark these wires as pairs. Take one wire each from a pair, and bolt them together. Then take the remaining two wires and hook them to a battery and see if it will run.
If all this checks out, then write back in and we will have to figure out some relays and stuff to make it go forward and reverse.
Old Apr 1, 2007 | 10:45 PM
redlineps's Avatar
redlineps
TX2 winch
I had previously checked that web site. They offer nothing as far as diagrams. What you offered makes sense. I'll try that and get back to you...Thanks...Moe
Old Sep 22, 2012 | 01:07 PM
ksraffel's Avatar
ksraffel
Thumbs up Tensen TX 2
I have a Tensen TX2 winch. If you are still trying to wire your winch I can provide pictures of my winch. My early Bronco has hook ups for winch mounts at the front and rear so it is a slide mount application and pics can be taken from any angle.
Keith Raffel
Costa Mesa, CA
Old Apr 18, 2013 | 09:46 PM
joemcco's Avatar
joemcco
TX2
Hello all, I have one of these old tx2's but I do not have the remote (4 pin) for it, does any one here know the wiring specs so that I can build one myself.
Details
Tenson Model 120
12v 2.2 hp
I have searched the internet and it almost like they don't exist.
Thanks
Joe
Old Apr 19, 2013 | 03:05 PM
Franklin2's Avatar
Franklin2
Details
Tenson Model 120
12v 2.2 hp
Thanks
Joe
Does it have the large 4 wires and can you make it work like I described above in the previous post?
Old Apr 29, 2013 | 10:39 PM
joemcco's Avatar
joemcco
Sorry for the delayed reply....yes it is the large 4 post connector. And I must be blind lol because I did not see the post about wiring it up.
Thanks for the reply and I will look for your instructs....up the line....
J
Old Mar 4, 2020 | 03:31 PM
Woodman567's Avatar
Woodman567
I am currently trying to find out how to wire up a TX2 winch same as yours. Did you find any wiring diagrams or owners manuals?
Old Mar 4, 2020 | 07:53 PM
Franklin2's Avatar
Franklin2
Again, did you try taking a meter and hooking it up like I wrote in the previous post?
Like this
TheSterling
Jun 15, 2020 05:40 PM
mrbdmorris
Dec 7, 2015 08:03 AM
Fordlover55
Electrical Systems/Wiring
Jan 22, 2006 11:26 PM
