Best Surge Cure
Old Apr 1, 2007 | 09:48 PM
hookd's Avatar
hookd
Thanks for the info guys looks like I know what I'm gonna be doing after next payday I gotta get this thing fixed before camping season. Thanks again.
Old Apr 1, 2007 | 10:01 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Originally Posted by Zwalters
What is a luggit, the only thing I can relate the sound to is a mack truck starting from a dead stop.
Basically the same thing. Dropping the clutch too fast, making the engine fall below the desired idle RPM and making it struggle to get back to idle. It sounds pretty cool and I can even do it with my automatic but it does not like it.
Old Apr 1, 2007 | 10:26 PM
indebt's Avatar
indebt
hookd if you do the WW with the turbo in, make sure you get the wobbly extension. If you dont its a PITA to try it with swivel extensions. If I were you I would order a set of o-rings and just pull the turbo and replce em all. The only reason I recommend this is that when I did my WW (Btw I already had an o-ring leak) I think all the wrenching made my leak worse. to pull the turbo it takes about 45min, to do the WW with the turbo in it takes about 45min ( so pulling turbo doubles your time since you have to reinstall) The advantage is you will be able to clean everything up and get those crapy pedestal o-rings some RR. Anyway go for it you will feel like king of the world when your neighbors see you pulling a turbo and thinking your awsome for atempting it.
90pioneer
Jun 29, 2014 12:41 AM
makomaker
35
Apr 29, 2008 07:57 AM
6spd
May 29, 2007 09:41 PM
otterdiver
Apr 26, 2006 12:24 PM
