Sponsored by: Innova
Replacing 2003 Escape 6 CD in-dash
Old Apr 1, 2007 | 07:47 AM
DBSweeney's Avatar
DBSweeney
Anyone know what wiring harness(es) are needed to replace the factory in-dash 6 CD changer? There are 3 plastic connectors, but all of the wiring kits from Scosche, etc. don't have anything that matches. I found one wiring kit that has 3 connectors, but it looks as though only 2 of them match up. The Haynes wiring diagram shows a very limited number of connections, so perhaps 2 of the 3 connectors are meaningless.
Can someone shed some light on this for me?
Old Apr 1, 2007 | 07:52 AM
joes52f6's Avatar
joes52f6
Not sure about the wiring deal, someone should be along shortly to help you out. Did you have a hard time getting the factory radio out? I've been trying to get mine out, but it won't budge. Any hints?
Thanks JOE
Old Apr 1, 2007 | 08:07 AM
IGoDwnTwn's Avatar
IGoDwnTwn
If its the premium radio as the one I upgraded to, yes its the third plug ( the left one) for the woofer. I upgraded from the Ford single cd/cassettte to the Ford 6CD changer and needed the pigtail (60 bucks) connector for that third plug.
IGO
Those newer radios have a srews behind the front face. In most cases you have to remove a front panel of some type to reach it. screws for that are usually on the inside top of the panel just befor the speedometer glass.
Old Apr 1, 2007 | 10:06 AM
DBSweeney's Avatar
DBSweeney
Thanks JOE
It was a little hard to get out. I pushed the removal tools in and pulled straight out on both resulting in the tools yanking out rather than the radio. What I did was make sure to jam the tool in as far as it could possibly go, then apply outward pressure on the tool and coax one side out at a time. Helps to rattle it up and down too. So basically, brute force.
Old Apr 1, 2007 | 10:07 AM
DBSweeney's Avatar
DBSweeney
IGO
Okay, so looking at it from the back the far left is the sub wires (on/off ?), the far right connector is the speakers, power, etc. and what's the middle connector for?
Old Apr 1, 2007 | 01:06 PM
DBSweeney's Avatar
DBSweeney
From left to right (looking from the back), can someone tell me what each are for:
Connector #1:
Connector #2:
Connector #3:
And here's the Scosche kit I saw that looks like 2 of 3 connectors are right (hard to tell though):
Old Apr 1, 2007 | 01:53 PM
cln2po's Avatar
cln2po
If there is a specialist car audio retailer near you - pay them a visit instead of Wally World - they will most likely have the harness you need.
And I know it wont be $3.99 but you would have saved some time/frustration for the $8 you saved.
Old Apr 2, 2007 | 10:29 AM
IGoDwnTwn's Avatar
IGoDwnTwn
Mine looks kinda different...on the rear across the bottom .....hmmm. I guess there might be different setups for the same type radio. The radio below is the one I purchased on ebay. The left grey female is where the woofer plugs goes.
IGO
PG Sorry for the big pic...not good at resizing stuff.
Old Apr 2, 2007 | 10:37 AM
IGoDwnTwn's Avatar
IGoDwnTwn
Mine looks like this:
Old Apr 2, 2007 | 10:40 AM
DBSweeney's Avatar
DBSweeney
Weird. Maybe my stereo's from an older Escape. Also, I'm in Canada if that changes things. I'm gonna go take a closer look at mine now...
Old Apr 2, 2007 | 10:46 AM
IGoDwnTwn's Avatar
IGoDwnTwn
If your radio has two small holes on each side of the front face...then that's a pre-2003 setup...the older ones that Ford used. The newer ones require you to remove part of the dash.
Old Apr 2, 2007 | 10:58 AM
DBSweeney's Avatar
DBSweeney
Ah right. Mine does have the two holes on either side, so it's an older model.
Old Apr 2, 2007 | 11:03 AM
IGoDwnTwn's Avatar
IGoDwnTwn
yes..I had to go to a Ford dealer to get my plug. Perhaps you can find what you need there...alittle more expensive...but you might get results.
Old Apr 2, 2007 | 11:10 AM
fordboy_52's Avatar
fordboy_52
you should be able to pick these plugs up at any sterio install shop
Matt
Old Apr 2, 2007 | 12:14 PM
Beerstalker's Avatar
Beerstalker
Looks to me like you need one of the following
Metra 70-5700
Bestkits BHA5700
Scosche FDK9B
Hope that helps.
