35-255-5 Cam
Old Mar 30, 2007 | 08:01 PM
77bigblock's Avatar
77bigblock
35-255-5 Cam
I recently rebuilt my 351W in my 92 F250. I put comp cams 35-255-5 cam in it. What have other poeple experienced for gas mileage with this cam? Did you have a drop? I know that my motor will suck gas until it loosens up. I was just curious. Mine just seems to really be sucking gas right now.
Thanks.
Old Mar 30, 2007 | 09:38 PM
Conanski's Avatar
Conanski
What kind of milage are you getting?
Does the truck have an OD tranny?
I'm assuming it's efi. Is it running properly?
Is is making good power?
Old Apr 5, 2007 | 03:41 PM
87beater's Avatar
87beater
I am looking to put the same cam in my 87 351W. Other than the crappy mileage (which I'm expecting) how do you like the cam? How does the truck run compared to the stock cam?
Old Apr 5, 2007 | 05:25 PM
77bigblock's Avatar
77bigblock
I really like the cam. It has a very good power band; down low, right where you want it. I pulled a K5 blazer 90 miles at 60-65 mph with no problems. I think my mileage will get better once the engine loosens up. I think I was just panicking. After all, it has less then 1,000 miles on it.
Old Apr 6, 2007 | 08:58 AM
Kemicalburns's Avatar
Kemicalburns
how many times have you changed the oil since?
Old Apr 7, 2007 | 05:08 PM
77bigblock's Avatar
77bigblock
The oil has been changed 3 times so far. Why do you ask?
Old Apr 9, 2007 | 08:48 AM
Kemicalburns
because at initial break in that is very important. crazy how dirty the oil is for the first 3000 miles on a fresh motor
Old Apr 9, 2007 | 07:21 PM
77bigblock's Avatar
77bigblock
the oil is pretty wierd looking, epecially after the first 20 minutes. I have been running GM EOS in there still, too. I figure that can't hurt anything. A little extra protection should be good for it. I also run Rotella 10W30 since that has a better add pack in it.
Old Apr 16, 2007 | 05:32 AM
77bigblock's Avatar
77bigblock
I figured I would update the thread that I started. I took a trip this weekend with the truck. With a mix of city and highway driving, I got 13 mpg. I think that is pretty good for a HD F250 with new engine. I figure I should be able to see a 1-2 mpg increase after it is broken in.
Old Apr 16, 2007 | 09:00 AM
Conanski's Avatar
Conanski
Originally Posted by 77bigblock
I figured I would update the thread that I started. I took a trip this weekend with the truck. With a mix of city and highway driving, I got 13 mpg. .
What tranny is in that truck? Do you have overdrive? If not that certainly impacted your milage, OD would add another 3-4mpg at HWY speeds(70mph).
Old Apr 16, 2007 | 08:28 PM
77bigblock's Avatar
77bigblock
I have an E4OD with 3.73 gears, 2 wheel drive, extended cab, long box, HD F250. I drive like a Grandpa, even though I'm 24. What do you get for MPG?
Old Apr 16, 2007 | 08:49 PM
Conanski's Avatar
Conanski
I get 16-17 HWY cruising at 70-75mph. Mixed driving is 12-14mpg. You are in the ballpark, I think it'll improve some more as the engine continues to loosen up.
Old Apr 17, 2007 | 02:18 AM
fishin machine's Avatar
fishin machine
I had my milage go up after I installed that cam. I also went to al heads and roller rockers. I went from 11mpg towing my boat thru the mountains to 12.
bearster18
17
May 2, 2025 05:45 AM
Dan_Johnston
May 13, 2015 04:13 PM
retired ironworker
Mar 29, 2014 10:03 AM
Putt
Feb 18, 2009 10:32 PM
jasonw302
Apr 6, 2005 09:41 AM
