Towing limit
Old Apr 22, 2007 | 08:41 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Something is wrong with the scales that your truck only weighs 4000 pounds on.
As I said mine weighs 8,000 pounds.
I do have 4x4 and a dump subframe under my flatbed, but that does not add up to 4,000 pounds of extra weight.
My guess is your lite weight would be close to 7,000 pounds on a 93.
Gr8ride, your weak point is the transmission.
Your low gear ratio is very close to what I have for second gear in my 4 speed with 3.55 gears.
Old Apr 22, 2007 | 09:13 PM
MandRServices1's Avatar
MandRServices1
I agree Dave S, My 93 weighs 7500 lb full of fuel 2 people in the cab and the cross box full of tools. My gooseneck equipment trailer weighs 7500 lb also, So empty im right about 15000 lb, not a real good light weight. I had a 580 Super K backhoe loader (about 12000 lb) on it the other day and did fine, not breaking any land speed records though.
Gr8ride, The numbers are probaly the same for a gooseneck or a bumper pull, but trust me youl feel a lot safer pulling any kind of weight on a gooseneck rather than a bumper pull. The weight is distribuited a lot better.
Just my 2 cents,
Mike
93 F-350 DRW 7.3l Factory Turbo 290000 mi. 4.10 5spd ext. cab
Old Apr 22, 2007 | 09:17 PM
justblowin'smoke's Avatar
justblowin'smoke
i've pulled alot of heavy loads with my old truck. a 20' steel gn stock trailer w/ around 7500lb of cattle. a 25' gn flatbed that probaly weighed 2500 empty w/ a 9000lb jd loader tractor (that was about a 45mph trip) that was with a 94 f350 7.3idi fac. turbo 5sp 4.10 gears
Old Apr 22, 2007 | 09:33 PM
Don Senkow's Avatar
Don Senkow
The 14,000 lb. rating with 4.10 gears is based on a 9,000 lb. trailer weight. That comes out of the 1989 owner's manual. Don
Old Apr 24, 2007 | 04:37 PM
MSC1's Avatar
MSC1
The scale was at a state landfill, they weigh your truck when you go in ( loaded ) & then again when you leave ( empty ) & you pay so much according to the weight of the stuff you dumped. I was surprise when they told me that my truck weighed 4000 lbs but i had no reason to question it untill now. Does anyone have any idea how much it would cost to weigh it at a truckstop?
Old Apr 24, 2007 | 06:52 PM
justblowin'smoke
some where around $10-20 i think i'll ask one of the drivers at work
94BULLITT
2009 - 2014 F150
Aug 12, 2013 07:44 PM
Pitcrw6
17
Jan 29, 2013 07:16 PM
wildstang
Jul 28, 2011 07:37 PM
SemperFiDevilDog
Mar 4, 2008 07:30 AM
ronha2
Jul 11, 2006 05:46 AM
