1978 - 1996 Big Bronco
351w in a 79 bronco?
Old Mar 18, 2002 | 10:53 PM
dereklovejoy's Avatar
dereklovejoy
I have a 79 ford bronco which has a 351w engine in it. I know its not the original that came in it. Well i took out the 351w engine because the tranny went and i had another bronco with a 302 and a good tranny and just put those two in the other bronco. Well now the 302 has crapped the bed and im wondering, what is that best move. Do i put the 351w back in and get a tranny for that or just go and get another 302 and put it in the bronco with the tranny ive got. thanks.
Old Mar 19, 2002 | 07:38 AM
83bigbroncoguy's Avatar
83bigbroncoguy
If the tranny from the 302 is still good, you can bolt the 351 up to that.
Old Mar 19, 2002 | 07:45 AM
dereklovejoy
you can bolt the 302's tranny right up to the 351w? some have told me both ways. if i can that would be great.
Old Mar 19, 2002 | 09:36 AM
83bigbroncoguy
The 4.9L 6 cyl, 302, and 351w all have the same bellhousing bolt pattern.
Old Mar 19, 2002 | 09:41 AM
dereklovejoy
thanks. maybe you can help me with another problem. i have another bronco with a 351c motor in it. the motor runs good and everything but the tranny in that is also gone. any idea about transmission in that?
Old Mar 19, 2002 | 04:39 PM
Bull's Avatar
Bull
Do you mean 351M instead of 351C? If it's the M block, it'll have C6 (if auto) with big block pattern for the bell housing.
Old Mar 19, 2002 | 08:57 PM
351Inside's Avatar
351Inside
351 Cleveland (built 70-74) has the same bolt pattern as the 302 and 351 Windsor. Be sure it's a Cleveland, not a 351M/400, which came standard in 78-79 Broncos. They look simular, but the deck height on the 351M is higher, hence a much wider intake. Also, true Clevelands had the heads matched to the intake by a 2 or 4 in the upper corners showing either 2bbl or 4bbl carb. 351M will have a M or nothing.
Old Mar 19, 2002 | 11:55 PM
dereklovejoy
ok so the 302's transmission will fit either the 351w or the 351c but not the 351m. You said the bold pattern is the same does that mean it will go on the 351c and work with no mods to it?
Old Mar 20, 2002 | 07:31 AM
351Inside's Avatar
351Inside
Yes, but keep the orgional flywheel with the engine.
Old Mar 20, 2002 | 10:39 AM
noseminer's Avatar
noseminer
4dddd
23
Jan 30, 2017 03:54 PM
Raedin
Engine Swaps
Aug 18, 2015 11:59 AM
Furr308
Apr 24, 2015 10:20 AM
RUSTY50F1
13
Sep 14, 2014 11:39 PM
TheMechanicalAnimal
Feb 10, 2010 11:41 PM
