1978 - 1996 Big Bronco
Gearing and Towing
Old Mar 18, 2002 | 11:06 PM
cajunbronco's Avatar
cajunbronco
Gearing and Towing
Old Mar 21, 2002 | 04:55 AM
Organdonor's Avatar
Organdonor
Gearing and Towing
I have a 94 XLT With a 302ci, a Flow Master exaust a hyperchip, headers, and a K&n filter. I do alot of towing locally(no more than 5 hour drive), I also have a 14' enclosed trailer that I use to haul my quads. On slight hills I have to shift out of overdrive to pull the hill due to my 31" tires (even with out my trailer). Will I benifit from gearing down for more pulling power? Or is this a waste of money? Also I'm planind a trip to Vegas this summer, will the 302 be ok on that long of a trip pulling a trailer?
Thanks
Old Mar 21, 2002 | 09:30 AM
honney's Avatar
honney
Gearing and Towing
>Will I benifit from gearing down for more pulling power? Or is this >a waste of money?
I'd go 4.10s personally.
> Also I'm planind a trip to Vegas this summer, will the 302 be ok on >that long of a trip pulling a trailer?
Don't see why not!
Old Mar 21, 2002 | 02:45 PM
Organdonor's Avatar
Organdonor
Gearing and Towing
Thanks
Old Mar 21, 2002 | 03:44 PM
scootin's Avatar
scootin
Gearing and Towing
If you don't have the tow package that came w. some broncos, you might want to think about a tranny cooler! Just an idea...
Old Mar 21, 2002 | 05:18 PM
MoabTamer's Avatar
MoabTamer
Gearing and Towing
You're going to have to shift out of OD no matter what you do to it. OD is simply too high of a gear ratio to tow in. If you check your owners manual I bet it will tell you not to tow in OD.
Old Mar 21, 2002 | 05:38 PM
beratte's Avatar
beratte
Gearing and Towing
Organ Donor, just a thought, make sure you have the right speedometer constant programmed in with your 31's. It will help with your tranny shift points.
Old Mar 21, 2002 | 07:39 PM
Organdonor's Avatar
Organdonor
Gearing and Towing
I have a trans cooler, that was a must! Even with out a trailer it still wants to shift out of over drive. What rmp is OK to haul for long periods of time in 3rd gear? 3000? 3500? It just worries me because it really sounds like it's winding out. 3500 rpm is going about 70mph.
Thanks
Organdonor
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
