trac bar bracket
Old Mar 29, 2007 | 07:48 PM
$Simpleman76's Avatar
$Simpleman76
trac bar bracket
I need to replace the trac bar bracket on my 78 f150 4x4 because the bolt hole in the bracket is elongated, do any of you know of someone who carries them, this is a stock truck with no lift, i ordered my bushings from the graveyard but i did not see a trac bar bracket listed from them, also the lower bolt in the trac bar is being stubborn because I can't get a socket to fit in the small space between the bolt head and the axle housing will try to recruit some help tomorrow and try again
thanks
Old Mar 29, 2007 | 08:31 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The bracket...with or without quad shocks?
Old Mar 29, 2007 | 08:34 PM
Buzzman's Avatar
Buzzman
Aren't your brackets riveted to the frame? The only place I have seen to get them is at a junk yard.
Old Mar 29, 2007 | 08:38 PM
NumberDummy
It's dinner time here in LA LA Land, so here's the part number for the bracket without quad shocks.
D6TZ-3B093-A .. Mounting Bracket, Front Suspension Track Bar
Bolt: 9/16"-12 x 3 1/2"
D6TZ-3B239-A .. Track Bar
Old Mar 29, 2007 | 09:24 PM
czaroc's Avatar
czaroc
I've found that you have to take the frame bolts (they aren't riveted on mine) off before you take the cross bolt out. There just isn't enough clearance between the steering box an all.
Old Mar 29, 2007 | 11:00 PM
yield2s's Avatar
yield2s
Hey I'll give you my stock bracket, just took it off my 77 F-150 4x replaced by a 4" drop one.
Old Mar 30, 2007 | 03:04 AM
$Simpleman76
yield i would be glad to take it off your hands for you
thanks
Old Mar 30, 2007 | 06:36 PM
yield2s's Avatar
yield2s
Hey Blake it's on it's way, USPS parcel 6-10 days.
Old Apr 19, 2007 | 04:53 PM
yield2s's Avatar
yield2s
Did you get the free part Blake?????
Old Apr 19, 2007 | 06:32 PM
gcfisher75's Avatar
gcfisher75
he's not looking for the bracket for the frame... he's looking for the one that is the front part of the radius arm C-bushing bracket... the one that wraps around the the front diff housing... he's talking about the opposite end of the trac bar.
Old Apr 19, 2007 | 07:53 PM
$Simpleman76
yield I did receive the bracket and it was the bracket I was talking about, it is a lot better than the one I had. Check your messages please
thanks
blake
NW 150
30
Jan 6, 2013 08:02 PM
mizzitch
Jul 18, 2007 12:53 PM
generalee31184
Apr 10, 2006 08:43 PM
T_Moss
Apr 3, 2003 09:59 AM
