1978 - 1996 Big Bronco
96 full cab roll cage
Old Mar 29, 2007 | 07:41 PM
TenPlugs's Avatar
TenPlugs
i'm getting a 96 bronco saturday and was wondering if there is a full cab roll cage because i want to remove the whole roof and wind shield. The truck will be for duning only so steet legal is not a concern.
Chris
00 F250 SD V10 CC 4x4
Old Mar 30, 2007 | 07:44 AM
lostin90s's Avatar
lostin90s
If you are cutting front roof off . Just go and get one made local . Looks are not a issue and strength is. The custom you can get made can have what ever mounts you want for storage ,eequipment mounts etc. Good luck
Old Mar 30, 2007 | 08:09 AM
Kemicalburns's Avatar
Kemicalburns
the cage will also need tied into the frame. any good fab person should know that though.
Old Mar 30, 2007 | 09:51 AM
justshootme84's Avatar
justshootme84
You can use a cage kit from places like S&W Racecars, I have their 10-point cage kit in my 84 Bronco. You still have to cut, fit, and weld it together, and tie into the frame. I also have mine tied into the cab thru the B-pillars' seatbelt anchor points. If you cut the roof off, you'll likely need some bracing to keep the body from flexxing apart. If you don't have good welding and fab skills, it's worth the $1000 or more to have a race shop build a cage for you. JSM84
1966Tbird
17
Oct 1, 2010 05:31 PM
Ibuildembig
Nov 8, 2007 08:43 AM
70velle
Aug 4, 2004 08:00 PM
orange peel
Offroad & 4x4
Sep 26, 2002 06:11 AM
