Roll cage for 87-96???
Old Nov 7, 2007 | 06:19 PM
Ibuildembig's Avatar
Ibuildembig
Anyone know of a company that makes an internal cage for a truck in this year range?
Old Nov 7, 2007 | 06:26 PM
ReadOrDie_DW's Avatar
ReadOrDie_DW
did a little searching as I have been wondering this myself, hope this helps:
http://www.redlinelandcruisers.com/1951441.html
Old Nov 7, 2007 | 06:37 PM
justshootme84's Avatar
justshootme84
Try www.swracecars.com I have one of their 10-point cage kits in my 84 Bronco, JSM84
Old Nov 7, 2007 | 06:39 PM
Ibuildembig
I looked at those, not too impressed with the HREW and thin wall stuff....mine is going in a rock crawler....just wanna make sure I keep everyone safe
Old Nov 7, 2007 | 06:44 PM
89frankenford's Avatar
89frankenford
i would suggest making your own. it would be cheaper in my opinion. thats if you know how to fabricate and use a welder. other then that i don't know any companies that sell roll cages for these trucks. you might have to go to a fabrication shop and have them make you one
Ibuildembig
Guess I posted too late.....the redline ones are the ones I think are too thin....the other ones look promising
Old Nov 7, 2007 | 06:46 PM
ReadOrDie_DW
ahh, I -was- gonna ask which type but ok, either way if your doing it for rock crawling then I suggest a custom job, the in cab ones can punch right though the sheet metal if you roll the truck a few times, direct bolt or weld to the frame is the path I would go.
http://www.brutaloffroad.com/cage.htm
good quality, good steel
Old Nov 7, 2007 | 06:47 PM
Ibuildembig
I have the tube, bender, welder, and know how....but pricewise its alot more for me to do it. I found the jegs sells a 12 pt for a 79 for 269.00 and with little mods, it will fit my application. So far I have enough to build a 10 pt 2" DOM .125 wall cage myself, but I have 675.00 in just the tube. This is the reason I was thinking about a prebent one, just to save my tube for something else.
Old Nov 8, 2007 | 07:44 AM
currituckF150's Avatar
currituckF150
How many sticks of tubing is that? If it is less than 8 you got ripped off! Plus 2" 0.120 DOM is not necessary. You not building a monster truck. 1-5/8" 0.120 DOM is more than sufficent.
Old Nov 8, 2007 | 08:43 AM
Ibuildembig
I bought 80 feet, or 4 20 foot sticks.
matt2491
19
Apr 25, 2018 12:33 AM
Orange91coupe
Nov 16, 2016 12:43 PM
Bingen08
Jan 27, 2016 07:36 PM
HotRodRob
Dec 30, 2015 12:48 PM
mdr617
Bronco II
Feb 27, 2011 02:31 PM
