Sponsored by: Auxito
F 150 Maintenance
Old Mar 29, 2007 | 06:36 PM
frdsforme's Avatar
frdsforme
F 150 Maintenance
Is it worth the $$$ to replace the spark plugs and fuel filter with 127 000 kms? The truck is running fine but was wondering if the replacement of these parts is necessary? Will it improve mpg?
2001 Ford F150 Supercab, 4.6 L 8 cylinder 4x2.
Thanks
Old Mar 29, 2007 | 06:45 PM
rsylvstr's Avatar
rsylvstr
fuel filter i get done every 15-30k MILES....plugs at 90K...if you plan on keeping the truck, it's worth the money
Old Mar 29, 2007 | 08:33 PM
steve(ill)'s Avatar
steve(ill)
if you havent had a plug fail yet, you are due. i would have them done this spring. the filter should ahve been done a long time ago. dont know about milage, but you might notice an improbement in performance. its probalby 80% plugged at 100,000 miles.
Old Mar 29, 2007 | 09:23 PM
PinkyRingz's Avatar
PinkyRingz
i always figure its better to spend the money on maintanance then having to rebuild your ride or scrap it.
Old Mar 30, 2007 | 05:44 AM
pat2724's Avatar
pat2724
Is there a link to do your own fuel filer on 01 5.4 f150?
Old Mar 30, 2007 | 10:16 PM
wtesh's Avatar
wtesh
F150 Maintenance
There is a special tool for changing the fuel filter, you can get it at Napa for around $10.
Old Mar 31, 2007 | 05:49 AM
pat2724's Avatar
pat2724
is changing fuel filter hard to do?
Old Mar 31, 2007 | 11:29 AM
preppypyro's Avatar
preppypyro
Maintenece like spark plugs, changing fluids, and filters are cheap insurance. Never hurts to do them sooner then later.
Old Mar 31, 2007 | 12:15 PM
liquid 1's Avatar
liquid 1
No its easy But you do need the correct tool, just ask at parts store..It makes the job simple..Be sure and get the ford tool..
Old Mar 31, 2007 | 02:33 PM
Octane's Avatar
Octane
Id put in new plugs and a new fuel filter before I traded up to something newer.
Old Mar 31, 2007 | 08:11 PM
pat2724's Avatar
pat2724
I don't want to sound like a idiot but where is the fuel filter and how do you get it off? What is a good filter to get?
Steve
Old Mar 31, 2007 | 09:34 PM
rsylvstr's Avatar
rsylvstr
Steve
it should be mounted under the truck on the inside of the left frame rail (crawl under the truck on the drivers side and you can't miss it). detach the safety clips from the lines (both inlet and outlet lines) and then use the special tool to disconnect the filter from the lines. you WILL spill some fuel, so don't sweat it (BTW, i never release the fuel pressure like you are supposed to)....loosen the filter mouting clamp, take it off and replace with a Wix filter from Napa (or where ever, www.fleetfilter.com ) or one from the dealer, or if you have to, a Purolator....
Old Apr 1, 2007 | 04:45 AM
pat2724's Avatar
pat2724
Thank you.
Old Apr 1, 2007 | 09:34 AM
rsylvstr's Avatar
rsylvstr
anytime....and please let us know how you make out....
Old Apr 1, 2007 | 04:44 PM
SuperSnake's Avatar
SuperSnake
What spark plugs do yall use? 97 F150 4.6L
