Sponsored by: Auxito
F 150 Maintenance
Old Apr 1, 2007 | 05:49 PM
rsylvstr's Avatar
rsylvstr
I use MC.....but have to admit, i had the dealer do mine.
Old Apr 2, 2007 | 09:28 PM
scottwoodman's Avatar
scottwoodman
I have a Haynes repair manual. It has step by step instructions with pictures on replacing the filter. Very simple job.
Old Apr 21, 2007 | 05:14 PM
slynch1033's Avatar
slynch1033
I am unable to remove the front (Engine side) fuel line from my 2003 Sport Trac. I have the fuel/AC line removal tools (the plastic kit) but cant get the front line to release. Is there a special tool for this like is mentioned elswhere on this site?
Old Apr 22, 2007 | 07:38 AM
svt2205's Avatar
svt2205
Just keep working at the filter. It's not moving because of a little bit of crud that's built up on the tube. Some come off easy and others don't. You will get it off, just be patient. Try spraying a bit of WD or other penetration oil in/around that trouble fitting, it might help soften up some of the crud.
As for plugs, I'm surprised no one mentioned this. DO NOT USE Bosch Platinums. You will have trouble with missing and poor overall running of the engine with them. I know I sure did.
Old Apr 23, 2007 | 06:36 PM
slynch1033's Avatar
slynch1033
Bought yet another tool at Auto Zone. They had never heard of the tool that is shaped like a pair of pliers. I have seen that one in catalogs. Took the tool back because after persistant tries with it, even though it was specific to Ford, would not work. I got it off using my fuel disconnect set that I started with. Will be a while before I change this one again....
Old Apr 23, 2007 | 07:04 PM
galaxie641's Avatar
galaxie641
I've resorted to having the dealer do the fuel filter when I happen to have the truck there for something else. My front clip started giving me trouble at about 80K miles and never got better.
Old Apr 23, 2007 | 07:13 PM
rsylvstr's Avatar
rsylvstr
i see that type hanging at AAP everytime I go...someday I'll get one.
Old Apr 23, 2007 | 08:49 PM
97F1504X4EC's Avatar
97F1504X4EC
Change the plugs and the filter, it's cheap insurance and you should notice a differance in power. I would recommend you use the Ford plugs as they seem to last longer then the other brands.
BigBlue92
Jul 29, 2012 04:40 PM
honkytonk
Apr 30, 2008 07:11 AM
ITDave
1997 - 2003 F150
Oct 13, 2004 12:49 PM
ceejcr
Modular V8 (4.6L, 5.4L)
Sep 15, 2004 09:45 PM
Pup
Oct 12, 1999 09:18 AM
