Sponsored by: Auxito
Nitrous on a 5.4
Old Mar 27, 2007 | 10:53 PM
F150 Boss 86's Avatar
F150 Boss 86
Nitrous on a 5.4
Ive just installed my 120 shot of nitrous on my 03 f150 boss 5.4 The truck comes with platinum plugs...does anyone know if these should be switched out? what should go in? anything else i should do to the motor? thanks for the help
Old Mar 28, 2007 | 04:29 AM
LxMan1's Avatar
LxMan1
Welcome to the forum
Usually with NOS, you need to run a colder plug. Get a set of Motorcrafts for a Lightning.
Old Apr 1, 2007 | 04:13 PM
monster buck's Avatar
monster buck
I use a 150 shot. Here are the musts. Platinum + nos = destruction.
NO PLATINUM. Go one step colder plugs, I use NGK. Must use fresh 93 octane min. If you normally run less of an octane rating, use up as much of it out of the tank as you can(arrive at station on fumes)and then fill with fresh 93 or higher. 93 is fine just don't pull up to a station out in bfe that the 87 button is worn off and the 93 has never been used. Forget about the octane boosters to take you from a tank of 87 to a 93 rating, it doesn't work that way. Also make sure you don't have a after market program on it like a hypertech or super chip that advances the timing.....=destruction. If anything at 120 you want 2-4 deg. lag. Stock will work at 120 but I rec. using a wet shot with a low fuel press sensor to shut off the nos if you loose fuel press.
Its all about pressure, don't shoot with less than a half a tank of nos. The pressure may be there at the start of the shot but will drop very fast and you will run fat and loose performance. Press......need heat.....use heater on bottle. Turn it on a good 30 min before use and it will turn on and off as the pessure fluctuates to maint. optimum bottle pressure. DO NOT USE A TORCH.
Lastly have fun,it rocks.
Old Apr 3, 2007 | 06:00 PM
F150 Boss 86
thanks a lot for the help. Ill need to order a new set of plugs and a heater. I had a superchips programmer but i took that off right away. anyone know of a program/chip to use with nitrous? thanks again...big help!
Old Apr 4, 2007 | 07:38 PM
monster buck
stock No. 4177 TR6(ngk), my hypertech fuel program is off but I still use the firm shift, higher 130mph speed limiter, and non-stock speedometer adjustments from it. I wouldn't mess with a "bought" ready mix porgramer for nos. Go stock or use a custom prgramer set up by a good shop from dyno runs. I use a cold fusion heater I got off ebay with a auto feature that uses bottle pressure to turn off and on. Unless you can read the bottle pressure in the driver seat then this feature is a must.
Old Apr 10, 2007 | 11:20 PM
F150 Boss 86
thanks a lot for the help. I got my new plugs in yesterday and man is it fun. what size of shot are you running? im interested to see how big i can go but yet still be safe, thanks again
Old Apr 11, 2007 | 08:57 AM
monster buck
I must reiterate, DONE RIGHT, a 100 shot is safe all day long, 150 is really pushing it, and yah I'm pushing it. Don't get to trigger happy. Keep the pressure up for each hit. It takes time to rebuild the pressure between hits. Heating time.
Old Apr 11, 2007 | 09:15 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
100 shot means 100 HP? Man i would like to know what that feels like... having it hammerd and then the NOS just kickin in..
Old Apr 2, 2021 | 03:46 PM
Kevin John's Avatar
Kevin John
2nd Gear
what fuel system are you guys using with nitrous I also have a 03 F150 5.4 2 valve I'm planning on running a wet shot nozzle system just not sure about fuel system
Old Apr 2, 2021 | 04:19 PM
Stonedpony's Avatar
Stonedpony
In case you don't know this post was made back in 2007. The year now is 2021 if you get my drift?
Try pinging them if they do not answer in a day or two if they still even come to this board.
One of the old timers could tell you more about how to do that or get a message to one of them.
43Duc
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
57
Mar 23, 2008 11:00 PM
GWIGG
1983 - 2012 Ranger & B-Series
Jul 18, 2005 03:33 PM
boxcar1974
Computer Chips & Tuners
Jan 19, 2004 08:34 PM
TI 3VOM
Jun 11, 2003 10:06 AM
pilot10
Jun 6, 2002 09:32 AM
