D66 turbo
Old Apr 10, 2007 | 05:19 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Beans' recomended max pressure for the D66 is 40psi.
Old Apr 10, 2007 | 08:45 PM
FARM69's Avatar
FARM69
Up to 40 lbs with stage one's, D 66, and some good tunes. Sounds like a pretty good deal to me.
Old Apr 11, 2007 | 06:46 PM
powerstroked162's Avatar
powerstroked162
it produces all grins over here
Cowboy Steve
Old Apr 12, 2007 | 05:52 PM
73strokin's Avatar
73strokin
So does the D66 automatically give you 40 psi of boost when you bolt it on? Or does it need special tuning (aside from a standard chip) and bigger injectors to make it work right?
Old Apr 12, 2007 | 06:02 PM
ForemanES's Avatar
ForemanES
It takes larger injectors and special tuning to run those injectors to produce more boost. 40 psi is the MAX psi the d66 is recommended for.
Old Apr 12, 2007 | 07:16 PM
powerstroked162
Bolt on form the turb might hit 27lbs but it flows gobbs of air. I had to tweak and peak the tunning and fuel flow to achieve max pressure. And it flows some serious air at 40psi. I have yet to hit 40psi on flat land but when under load on a good grade it really slams that needle on the boost gauge. Its all smiles
Cowboy Steve
Old Apr 13, 2007 | 11:31 AM
FARM69's Avatar
FARM69
I wish I could be in your situation. If you keep talking it up steve, I'm gonna have to write the check for it...
Old Apr 13, 2007 | 01:35 PM
ForemanES's Avatar
ForemanES
No kidding, I am now researching how long a stock turbo will support 30+ psi. If I would just stop and fix those uppipes I would be making a lot more boost.
Old Apr 16, 2007 | 11:20 AM
powerstroked162
Its rightup your guys allies! The turbo is phenomenal. I hauled a load yesterday from Yakima to Ellensburg and the temps would get a little hot but never saw anything over 1000* loaded, no IC. I was really pleased. The turbo also cools alot quicker then the stocker unit did. I can hit 1200* and let off and be back in it starting from 600*. Like I said, at 40psi loaded its a screamer, at least thats what the guy told me at a gas station when i blew by him and his "chipped" cummins, while i was loaded mind you! lol, he wasn't all smiles but I sure was
Cowboy Steve
Dan V
23
Mar 7, 2018 11:00 AM
jayhawk714
Feb 12, 2017 04:35 PM
RV_Tech
32
Nov 26, 2016 10:29 AM
darknight
18
Sep 1, 2015 09:09 AM
mitchf2506.0
Dec 10, 2010 10:08 PM
