transmission bucking
Old Mar 27, 2007 | 08:53 PM
rpss4844's Avatar
rpss4844
i have an 05 f250 PSD and i have noticed that under light to medium acceleration the transmission will buck or surge, if you will! it mostly happens between 3-4 and occasionally between 2-3. When it happens the rpma will jump up before the gear change is complete. when pulling a trailer this can be a very violent and harsh gear change with the truck upshifting and then downshifting immediately. i have to let off the throttle for a sec then get back into it! any ideas on whats going on, anyone else experience these problems?
Old Mar 28, 2007 | 08:20 AM
Kenwood's Avatar
Kenwood
Id almost bet MONEY its not the trans.. My MONEY is on EGR valve.. Go get the codes pulled.. My guess is PO404 Po405.. When Mine first started pulling that mess I thought the same thing.. But it ended up being EGR... Im fighting that problem AGAIN.. I really need to study up on what it would take to make a no CEL dummy egr..
Old Mar 28, 2007 | 09:36 AM
Storm's Avatar
Storm
Gimme an "E"... "G".... "R".....
It's probably EGR... Just a lil TLC and you'll be good as good
Old Mar 28, 2007 | 09:42 AM
l-m tech's Avatar
l-m tech
check these tsb's. 06-22-6 , 07-5-11 , 07-6-9.maybe this will help.
Old Mar 28, 2007 | 08:10 PM
rpss4844's Avatar
rpss4844
i only have 28k miles, should the EGR be giving problems this soon? Is there a website i can check those TSB's at?
Old Mar 28, 2007 | 10:38 PM
Storm's Avatar
Storm
Oh yes.. I bought my truck in January.. Had 26,700 mi... It had the same problems when I took it for the weekend.. When I signed the papers I had them fix it.. Was a bad EGR, needed cleanign.. Those coke up real quick..
Old Mar 29, 2007 | 10:33 AM
rpss4844's Avatar
rpss4844
ok after countless time reading through EGR this and EGR that, i have come the the conclusion that for all pratical purpose it is better to just disconnect the EGR. I am pretty sure by doing this I am going to get a CEL! I also understand that a tuner can be tuned to just add a "EGR delete" if you will to the computer so you get no CEL.
I havent read anywhere of other people having the same problem i am having with the rpm's flaring between gear changes.
please correct me if I am wrong or if i need to go back re-read the information.
Old Mar 30, 2007 | 07:58 PM
Z-MAN's Avatar
Z-MAN
My 03 6.0 Is In The Shop For That Exact Tranny Issue Havent Heard From My Dealer Yet, But Some People Here Think Its A Pressure Problem Aka. Pressure Selinoids. I Will Post My Results As Soon As I Get Them, Also Are You Having Any Hesitation When Putting It In Reverse Or Drive Or Hard Ingauging I Also Have This Problem As Well. Good Luck Let You Know Soon.
Old Mar 30, 2007 | 08:08 PM
WishIhada7.3's Avatar
WishIhada7.3
i wouldnt unplug the egr.....my effects were loss of power/boost.
Old Mar 30, 2007 | 08:10 PM
bnmccoy's Avatar
bnmccoy
Do you have stock tire size?
R U running a tuner?
Son-in-laws dad was telling about a similiar problem he had that was resolved by getting tire size corrected in ECM.
I have also heard of 'flare' between shifts with some tuners but this was at full throttle.
Good luck with your problem,
Bob
Old Apr 1, 2007 | 12:00 PM
rpss4844's Avatar
rpss4844
the truck is 100% stock no tuner and still the factory tires!
ZMAN, I havent had any problems with it going in gear only the "flaring" between 2-3 and sometimes 3-4. please let me know what the stealer finds out about your truck it will kinda give me a starting point, for the mean time I am going to clean the EGR and see if that helps. thanks to all for the concern and for the advice!
Old Apr 1, 2007 | 05:32 PM
06stroke's Avatar
06stroke
i have the same problem with mine it histates a little before engaging into gear and under hard excelleration it hesitates ALOT sometimes under full throtel it goes as far as completely missing the gear it seems like. sound like the egr needs clean? my truck is also completely stock except for 5inch exhaust. someone give me a link to the cleanin procedures? thanks alot
Old Apr 5, 2007 | 06:04 PM
Z-MAN's Avatar
Z-MAN
Not Good News The Snap Ring Is Letting Loose And There Is Metel Shavings In The Pan, Its Ready To Leave Me Stranded Somewhere, So Its Rebuild Time About $1,500-2000 Parts And Labor, The Issue With Hesitation Was That The Selinoids Act Like Magnets And Pick Up The Metal. Hope You Have Better Luck If Your Trans Is Still Under Warranty Dont Wait. Also After Reflash Truck Wouldnt Start Right Chugging Smoke And Wouldnt Turn Over For A Long Time Mechanic Said Some Injectors Taking A Crap Will Fix Under Warranty After Trans Fixed. I Miss My Baby Already. Z-man
Old Nov 18, 2023 | 04:36 PM
JRwright's Avatar
JRwright
1st Gear
hello, im having this problem currently out of my 2005 f350 my egr is blocked off so I dont know how it could cause problems im stumped.
Old Nov 23, 2023 | 08:00 PM
BryanStein's Avatar
BryanStein
This is a 16 yr old thread, JR. I highly recommend starting a new thread.
jtproudlogger
Jun 1, 2012 05:18 PM
j4henry
Jun 10, 2011 02:08 PM
mcprjmngr
May 2, 2008 10:46 AM
2-tall
Apr 12, 2006 05:33 PM
mudbone1979
Bronco II
Dec 12, 2004 11:40 AM
