Has anyone used a TS performance chip? I was thinking bout ditching my superchips programmer. The TS goes for a pretty good price on Ebay. Is it better than my superchips programmer?
------------Jeremy
as Itfox said ditch the programmer for sure. lots of guys running the TS and like it but every one that I have heard that have switched to either tony or dp-tuner would never go back. I have not heard of one that wish they had stuck with the TS.
Well i only wanna spend 200-300 bucks and for 275 with free shipping i can get the TS with 4 pos. 50, 75, 100, 140. Is this a good deal could Tony do better?
-------------Jeremy
I bought that same chip on Ebay last summer. I installed it and it works excellent! What a difference in power! I can't say first hand how it compares with the DP or Tony, but from what I read on this forum it is definitely going to be better than the Superchips or Edge.
Cool thanks, you really cant beat the price for the amount you get. 73strokin what programs did u get? And do they all work as should? What type of MPG increase did you see with it?
------------------jeremy
I am pretty sure you can get that same 4 pos chip from Tymar performance for 225 bucks. You will be able to select the 4 programs you want, and if you do not like it he'll let you send it back and get a different tuners programs put on.
That and you are dealing with a person and not an ebay account.
I got the 50, 75, 100, 140, stock, and high idle programs. They all seem to work as should, I usually run the 75 setting and I see mabey 1-2 mpg increase. Also, I was told by TS Performance that in order for the 100 and 140 to increase output by that much, I will need bigger injectors.
