Intermitant Check Engine Light
Old Mar 26, 2007 | 08:55 PM
1stBronco's Avatar
1stBronco
As stated, the light comes on about once or twice a week for a period then goes out for a few days. No noticeable regularity to it. Only thing I do notice is a tapping noise from the right side of the engine on occasion. Any ideas?
Old Mar 26, 2007 | 10:04 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
You need to have codes pulled. If your vehicle is 1996 or newer (OBDII) even though the light went back out, it should still have the code stored.
Have someone pull your codes and post the results here, we'll try to help.
Old Mar 27, 2007 | 10:22 AM
aquanaut20's Avatar
aquanaut20
96+ will have freeze frame info as well, stores specs at the time of the code setting, usefull information to have.
Old Mar 27, 2007 | 08:41 PM
1stBronco's Avatar
1stBronco
Thanks, I will get that done and be back
Old Mar 29, 2007 | 02:23 PM
1stBronco's Avatar
1stBronco
Got a code P1400 and was told by auto zone that it is a dealer only code and no idea what it means. Called the ford dealer and was told that the egr system needed to be checked. It could be the DPFE or a number of other things. Told the cost would be no more than $400.00. I have a 2002 Exp. w/ 4.0 SOHC and 72,000 on it. From searching here, the going thought is to replace the DPFE. Is this still a good plan?
Old Mar 29, 2007 | 04:45 PM
aquanaut20's Avatar
aquanaut20
http://rockledge.home.comcast.net/RangerPictureGallery/DTCs.pdf
http://groups.msn.com/RangerBill/rangermodifications.msnw?action=ShowPhoto&PhotoID= 677
Old Mar 29, 2007 | 04:56 PM
aquanaut20's Avatar
aquanaut20
https://www.ford-trucks.com/lc/lc.ph...tage-Test.html
Old Mar 29, 2007 | 05:21 PM
mikeinri's Avatar
mikeinri
Thanks for those links aquanaut.
I have a 94 with DPFE/EGR codes, so I am very interested in the last link (the test procedure).
One question: If the "wire harness remains plugged into the DPFE sensor for this test," where do you probe with the DVM?
Here is the specific history of these issues. All codes were KOEO (or CM).
Nov 25 06:
332, Insufficient EGR flow detected<O
Replaced manifold-to-DPFE tubing, no more codes<O
<?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com[img] /><st1:date Month=[/img]Nov 25 2006</st1:date>:<?xml:namespace prefix = o ns = " /><st1:date Month="2" Day="2" Year="2007">February 2 2007</st1:date>:
336: Pressure Feedback EGR (PFE) sensor or EGR Pressure Transducer (EPT) - signal voltage higher than expected (exhaust pressure high)
<O</OAND
<O</O337: EGR Valve Position (EVP) sensor, Pressure Feedback EGR (PFE) sensor or EGR Pressure Transducer (EPT) - signal voltage too high
<O</OReplaced DPFE, no more codes
<O</O<st1:date Month="3" Day="12" Year="2006">March 12, 2006</st1:date> (to present):
<O</OCode 327 = EGR, EVP, PFE, or EPT signal voltage too low
I'm off to buy a vaccuum pump so I can check it this weekend. Any help would be greatly appreciated!
Mike
Old Mar 29, 2007 | 06:05 PM
1stBronco's Avatar
1stBronco
Thank you, Thank you. I will be leaving town for the weekend, but know what to do when I get back. Again thank you and will post back when completed.
Old Mar 29, 2007 | 06:33 PM
aquanaut20's Avatar
aquanaut20
This is an overview of the EGR system.
http://rockledge.home.comcast.net/Ra...dEGRSystem.htm
Old Mar 29, 2007 | 09:32 PM
mikeinri's Avatar
mikeinri
Well, I have no idea how all those smiles got into my message. Yikes...
Anyway, thanks for the additional picture, very helpful.
My question from above is, how do I connect a voltmeter to a sensor without disconnecting the wiring harness? Do I have to put a hole in the insulation? I would really prefer not to do that (fear of corrosion).
Mike
Old Mar 30, 2007 | 12:30 AM
aquanaut20's Avatar
aquanaut20
I have used straight pins and/or paperclips to gain a connnection into the connector, whatever works best. If you have to pierce the casing a swipe with silicone will seal any puncture.
turbo930ss
13
May 17, 2013 12:36 PM
hamiltonfighter
Jul 14, 2012 09:52 PM
katdaddy
Jun 17, 2006 10:26 AM
hillra99
1997 - 2003 F150
Oct 5, 2001 07:17 PM
