As stated, the light comes on about once or twice a week for a period then goes out for a few days. No noticeable regularity to it. Only thing I do notice is a tapping noise from the right side of the engine on occasion. Any ideas?
Got a code P1400 and was told by auto zone that it is a dealer only code and no idea what it means. Called the ford dealer and was told that the egr system needed to be checked. It could be the DPFE or a number of other things. Told the cost would be no more than $400.00. I have a 2002 Exp. w/ 4.0 SOHC and 72,000 on it. From searching here, the going thought is to replace the DPFE. Is this still a good plan?
Well, I have no idea how all those smiles got into my message. Yikes...
Anyway, thanks for the additional picture, very helpful.
My question from above is, how do I connect a voltmeter to a sensor without disconnecting the wiring harness? Do I have to put a hole in the insulation? I would really prefer not to do that (fear of corrosion).
I have used straight pins and/or paperclips to gain a connnection into the connector, whatever works best. If you have to pierce the casing a swipe with silicone will seal any puncture.
