6637 mod
Old Mar 26, 2007 | 03:49 PM
Izzy351's Avatar
Izzy351
A lot of guys (like me) just shove the stock intake hose over the neck of the filter. It will fit, but it is tight. As a precaution, clean the intake tube around that area to remove any oil residue that might make it want to slip off. Also, trim the tab mentioned already, as well as a little of the alignment tab that the stock clamp has a slot for. If you do that, you can reuse the stock clamp. You can also rough up the filter neck a little to give it more bite. I didn't and haven't had it loosen up.
Here's what mine looks like:
Old Mar 26, 2007 | 03:51 PM
F250_'s Avatar
F250_
Having seen your pic several times, now, I've been curious about something, Izzy. You didn't leave the DuraLife sticker on after you finished the install, did you?
Old Mar 26, 2007 | 04:07 PM
Izzy351's Avatar
Izzy351
Why? Should I have peeled it off? Never occurred to me...
(So, yes it's still there)
Old Mar 26, 2007 | 04:51 PM
F250_'s Avatar
F250_
I'm sorry, Izzy... I guess the engineer part of me gets a little **** about these things sometimes. I know that it will make virtually no difference in air flow, except out at probably the 3rd or 4th decimal place. I removed mine just to remove the tniy bit of air flow restriction that it might cause, and stuck it back on the end of the filter under the filter cover I made.
Old Mar 26, 2007 | 05:39 PM
Izzy351's Avatar
Izzy351
LMAO..... Okay, I'm with you now. But now that I think about it, won't your cover add more restriction, too (even if it's the third or forth decimal place)....
Sorry, had to say it!!
Old Mar 26, 2007 | 06:47 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Owned!
Izzy i have to admit that is good. Pete walked right into that one
Old Mar 26, 2007 | 06:53 PM
Uzumati's Avatar
Uzumati
1 point for izzy
Old Mar 26, 2007 | 08:28 PM
F250_'s Avatar
F250_
I'll give him 2 points myself. I actually thought about that and almost said it myself, but I figured I'd just toss out the bait and see who caught it!
Good eye, Izzy!! And if you really want to take your point to my "****" level, my iron-on transfer image alone is larger than your sticker, and there's NO air passing through my image while SOME air goes around your sticker!!
Old Mar 26, 2007 | 08:38 PM
Izzy351's Avatar
Izzy351
It's all in fun....
I'm off to the rack. Had too much fun out on Panama City Beach over the weekend and my last post in another thread wore me out. Cranking down the AC to cool off my sunburn...
Old Mar 26, 2007 | 11:08 PM
travis dasher's Avatar
travis dasher
Originally Posted by Izzy351
It's all in fun....
AHHHHH!!!! Spring Break.... Gotta Love it
Old Mar 26, 2007 | 11:13 PM
John311t's Avatar
John311t
I have never went on spring break.
Old Mar 27, 2007 | 08:16 AM
Izzy351's Avatar
Izzy351
If you leave now, you can catch the tail end of it.
Old Mar 27, 2007 | 04:07 PM
  #28
John311t's Avatar
John311t
Na, i got stuff to buy for my truck. Maybe next year...
WHT00EX
58
May 5, 2012 12:46 AM
TheBludgeon
Oct 15, 2011 01:01 PM
todd jo
Jul 3, 2009 05:16 AM
fordsbyjay
15
Jan 27, 2008 09:16 PM
todder53
Oct 10, 2005 10:08 PM
