3.0 Throttle Sticking
Old Mar 25, 2007 | 06:48 PM
jv42287's Avatar
jv42287
Angry 3.0 Throttle Sticking
3.0 6cyl, 120,000 mi, 5spd, 4x4. Engine runs fine and all is well to my knowledge. However, the throttle seems to stick after i run it above 2k rpm for a while. Also, if i try to bring it down by putting it in gear the idle just goes up on its own after i press the clutch. Other than that it just idles high, which i have tried to fix. I cleaned the MAF, replaced the IAC, and checked the vacuum hoses for the most part, there is a vacuum. I am not sure what to do next. Any ideas?? Thanks, John
Old Mar 25, 2007 | 07:14 PM
chbtech's Avatar
chbtech
I would remove the TPS to make sure it's not worn, binding, broken, etc. After that, check for fault codes.
Old Mar 25, 2007 | 07:37 PM
JeremyJ's Avatar
JeremyJ
i have a sticky idle also,when i come to stops, i push in clutch and rpm's rise to about 1200-1500.
i have yet to solve problem thought i tested my iac and it works fine.
i have no codes according to my scanner.
Old Mar 26, 2007 | 12:29 AM
Benaghetto's Avatar
Benaghetto
A buddy of mine's camaro did the exact same thing before he sold it. I never could figure out to the best of his limited knowledge what caused it. He never was one for maintenance either so I firugred in his case something simple is what caused it. Tho his O2 censors always threw him a fit. When was the last time you did a thurough tune up on your truck? I see you did clean the MAF and replace the IAC. What did you use to clean the MAF? BTW what year is your truck?
Old Mar 26, 2007 | 12:52 AM
Benaghetto's Avatar
Benaghetto
Also, have you verified the fact that your butterfly is 100% closed at idle? Try starting the engine and removing the intake tube from the throttle body to check it out. Just be careful of that fan!
Old Mar 26, 2007 | 07:17 AM
JeremyJ's Avatar
JeremyJ
if the butterfly is open, how would you fix it?
Old Mar 26, 2007 | 07:57 AM
fordboy_52's Avatar
fordboy_52
new return springs
Old Mar 26, 2007 | 08:50 AM
JeremyJ's Avatar
JeremyJ
Originally Posted by fordboy_52
new return springs
and what springs are these and where are they located?
thanks
Old Mar 26, 2007 | 08:56 AM
fordboy_52's Avatar
fordboy_52
should be some springs on your throttle body. one of mine broke and i replaced it with a standard spring set from the parts store
Matt
Old Mar 26, 2007 | 09:15 AM
JeremyJ's Avatar
JeremyJ
and may i ask how your truck was acting when it broke?
thanks for the advice.
Old Mar 26, 2007 | 10:53 AM
fordboy_52's Avatar
fordboy_52
my pedel was just easier to press and didnt return to idle correctly, went underhood and reved it on the engine and noticed it had nothing pulling it back
Matt
Old Mar 26, 2007 | 02:33 PM
jv42287's Avatar
jv42287
It is a 97, sorry about that. Also, i cleaned the MAF with carb cleaner, like the tech post says to. I will have to check out the throttle springs and try to clean that out. Thanks
Old Mar 29, 2007 | 09:55 AM
JeremyJ's Avatar
JeremyJ
i dont see how pushing the clutch in would cause the idle to go up due to bad springs.
i need to clean my maf and check my tps.
Old Mar 29, 2007 | 05:35 PM
97ranger xlt's Avatar
97ranger xlt
pcv valve.
Old Mar 29, 2007 | 11:34 PM
Benaghetto's Avatar
Benaghetto
It'd rev up due to less stress on the engine! Its like turning your AC off.
