Tach died
Old Mar 23, 2007 | 08:13 PM
oops's Avatar
oops
Tach died
What are the causes of tach failure? No CEL, No rough idle, no other problems. Just no tach.
Andi
99 Ranger 3.0 FFV
Automatic
Old Mar 23, 2007 | 08:25 PM
crazypaw's Avatar
crazypaw
Talking Dead Tach!
Hi oops,
Unique moniqure! Electrical Disconnection is my #1 guess!
Old Mar 24, 2007 | 06:58 AM
oops's Avatar
oops
Not to sound dense but what might be disconnected.
The story behind the moniker is that something always seems to happen. I have done thing backwards, and sometimes completely wrong, and its really a surprise when it actually works. This is what happens when dyslexia meets the real world and the only one you can afford to pay is yourself.
Andi
Old Mar 24, 2007 | 12:02 PM
MemphisSenior's Avatar
MemphisSenior
Could be something as simple as a blown fuse. I was changing the light bulb in my overhead cab light and accidently grounded something. Next thing I know I have no speedometer.
Old Mar 24, 2007 | 06:55 PM
fflintstone's Avatar
fflintstone
If it's got a distributer, check the lead coming from it. Seems to me those older systems used a signal from the distributer for the tach.
Good luck
Fred
Old Mar 24, 2007 | 06:58 PM
fflintstone
Sorry For some odd reason, I was reading the specs off of Crazypaws sig. You definitely have a distributerless unit. As far as I know, she gets her signal from the computer. Like the guys were sayin', check the connections and fuses.
Fred
Old Mar 24, 2007 | 08:15 PM
oops's Avatar
oops
Sorry for not responding back sooner but I was gone all day with my mom.
Yes my truck is distributorless. For some unknown reason the tach has started working again. When I turned it on this morning it was showing rpms. Been showing rpms all day. I am still confused as to what might be causing this.
Andi
Old Mar 26, 2007 | 10:34 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
It's probably the tach itself. If the computer isn't receiving the tach input, it will throw on the engine light.
So it's either the wiring between the comp and the IC, or the tach itself.
Mine's doing some goofy things too.. bouncing around and stuff.. i think it's about to fail also.
Good luck.
Old Mar 27, 2007 | 08:07 PM
oops's Avatar
oops
The CEL is now on but I haven't had time to have it checked, possibly on Friday. The tach is working but it is bouncing around a lot. Sometimes it completely bottoms out and a few seconds it will spring back to life. It may do this once r it may do it several times in a row. I still don't hear or feel anything wrong.
Andi
Old Apr 8, 2007 | 01:38 PM
crazypaw's Avatar
crazypaw
Wink
Hi oops,
Well whats the diagnisis Doctor??? What did you find???
All info is welcome and needed here at FTE for the next person with your situation or simular!!
ptr34
6.4L Power Stroke Diesel
Dec 18, 2008 05:07 AM
charles jones
Jan 7, 2006 07:59 PM
jqp00002
Apr 6, 2005 12:01 AM
SouthPCraz
1978 - 1996 Big Bronco
May 31, 2003 12:22 PM
CJay
Mar 20, 2000 01:10 PM
