390 dizzy, coil, tach wiring Need to check this
I just wired up my dizzy, coil and tach and wanted to check my wiring before I tried to start this engine. I have the pertronixs in my dizzy. My tach has the sun super tach works in it
Coil + Red to dizzy, red to tach and red from the ignition
Coil - Black to dizzy and black to tach
Ground - green to tach
Thanks in advance, Charles
Mike, I can not find where i put my tach wiring diagram. I think it said red wire to + on coil, black wire to - on the coil and green wire to ground. I wired the pertronixs red wire to + on the coil and black wire to - on the coil. Then I put the red wire from the ignition to + on the coil. I guess it is from the ignition it comes out of the fire wall in a bundle and I'm nearly sure it went to + on the coil. How do you think the tach should be wired? Sun Super tach works in my tach. I can call and get the info Monday but if I get it right I will start this up tomorrow. Thanks for the help
Brother Les
08-28-2014 03:23 PM
03trueblue
08-26-2012 09:30 AM
bruno2
02-21-2012 10:00 PM
