Sponsored by: Real Truck
power rear window
Old Mar 23, 2007 | 01:08 PM
bronco521's Avatar
bronco521
power rear window
has anyone had any trouble with the factory sliding window?i opened mine today and went to shut it and it only made it about half the way and stopped.had to help it the rest of the way.
Old Mar 23, 2007 | 01:21 PM
tazo's Avatar
tazo
I have never had problems with mine. But if it is dirty it will open and close slowly. I clean the window and the weatherstripping. I then use a little spray silicone on the track and it works like it should.
Old Mar 23, 2007 | 01:27 PM
msgtg's Avatar
msgtg
I assume you're talking about a manual slider? If so, I concur with tazo...I 've taken a can of compressed air and blew out the gunk from the tracks and then a little spray silicone. It's always worked for both of mine.
Old Mar 23, 2007 | 08:35 PM
bronco521's Avatar
bronco521
no,it's power.stopped at the dealer today and there is a service bulletin regarding this so the truck is going in monday.
i was wondering if anyone else had this problem.
Old Mar 25, 2007 | 07:30 AM
Grifstoy's Avatar
Grifstoy
i have, so what was the dealers response, i did what Tazo said and it was fine for a while...
Old Mar 25, 2007 | 08:39 AM
Stevesdiesel's Avatar
Stevesdiesel
Mine is on a 2005. I just had it replaced for the third time,Same problem with it opening half way and sometimes would not close. The dealer said that they only have had a couple trucks with this problem?
Old Mar 25, 2007 | 10:50 AM
del_allen1957's Avatar
del_allen1957
I had my 04 in this week for the power slider. Had to order parts. Suppose to take it back Wednesday.
Old Mar 25, 2007 | 11:51 AM
bronco521's Avatar
bronco521
the service manager read the service bulletin and the suggested steps to go about diagnosing/fixing and there were a few different things they were going to have to look at.it's going in tomorrow.
the last couple inches or so closing as been slow since the truck was new but it always closed.first time i opened it this year and it wouldn't close on it's own.
Old Mar 25, 2007 | 01:18 PM
mlb4966's Avatar
mlb4966
Mine seems sluggish at times but I honestly havent opened it since August of last year.
Old Mar 25, 2007 | 03:45 PM
bronco521's Avatar
bronco521
when does it start to warm up up there?
Old Mar 25, 2007 | 05:08 PM
mlb4966's Avatar
mlb4966
What is thy meaning of warm? I usually have to mow the grass around the snow in May but by June it's all gone. In late Sept I am usually mowing around the ice or snow again. Warm for me is anything in the 40's.
Wish I knew about the TSB for the rear window. I just got my truck back from the ford dealer for the ABS Light due to a bad sensor in the rear diff. It's a 12 hour drive so I had to take vacation time for that. The only reason I use the rear sliding window is to equalize the pressure of the cab when the moon-roof is open.
Old Mar 25, 2007 | 07:40 PM
bronco521's Avatar
bronco521
just warm enough to have the slider open.and that would depend on how tough a person is.
i didn't know about the tsb either.i was at the dealership getting my oil changed and walked over to the service man and asked about the window.he got on the puter and found the tsb.hopefully this fixes it.
Old Mar 26, 2007 | 01:04 AM
blackhat620's Avatar
blackhat620
Here is a link to the TSB
http://www.ford-trucks.com/tsb/fullt...hp?tsb=06-15-5
Hope this helps.
Old Mar 26, 2007 | 10:25 AM
mlb4966's Avatar
mlb4966
Thanks,
I printed it out and will put it in the center console until I make it to town again.
Old Mar 29, 2007 | 11:51 AM
bronco521's Avatar
bronco521
just an update,the dealer has to replace the whole window.apparently the motor was bad.they had to order it so the truck has to go back in this coming monday.
