Modular V10 (6.8l)
oxidation on coil pack "spring"
Old Mar 23, 2007 | 11:19 AM
emptyd's Avatar
emptyd
Question oxidation on coil pack "spring"
When I just changed out a malfunctioning coil pack I was surprised to find a whitish powedery oxidation on the coil pack blade-like contact, on the "spring" that connects to the plug, and on the plug contact end of the "spring".
I also just had my plugs replaced and all of them seemed to have this same thing. Is there any kind of treatment that I can use on the metal parts at their contact points to keep the from oxidizing (or what ever it is) but still provide excellent conductivity for the spark impulse?
At first I thought dielectric grease, but isn't that supposed to be non-conductive?
Old Mar 23, 2007 | 12:01 PM
Fredvon4's Avatar
Fredvon4
Yes by definition "dielectric" implies NON conductive and this is exactly what you want
But beware not all "dielectric" greases are non conducting so caution is needed using any of the stuff-------- Less is always better then More
The theory is...non conducting grease on electrical contacts is displaced by the connecting action leaving a metal to metal conductive path while surrounding the entire area with the grease barrier to slow down corrosion and keep water out
Since you might get greases that are deliberately designed to conduct but still erroneously labeled as "dielectric" grease you need to be careful to use small enough amount and not bridge the electrical contact to ground unless you know the product is truly a dielectric
Old Mar 23, 2007 | 12:05 PM
emptyd's Avatar
emptyd
Excellent description - thanks! In this particular case I don't think there is much chance of bridging to ground since everything is surrounded by / covered by that rubber boot.
Old Mar 23, 2007 | 12:19 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Spark has a wonderful way of finding ground and avoiding the plug
Just clean up the end of the cop with a wire brush (carefully), and replace all the boots and springs.
Put dialectric grease on the ends of the boot, preferably on the inner lip, and fit it to the COP. This'll keep moisture away from the spring and the end of the cop.
Then, when putting the cop back in, put dialectric grease around the seal lip on the boot. This will help keep moisture out of the spark plug hole.
Old Mar 23, 2007 | 12:21 PM
Fredvon4's Avatar
Fredvon4
Ah..but you did not have to track down the miss fires that were caused by my buddy who used a Kopr Grease for its thermal and anti corrosion qualities forgetting about the conductivity of the stuff and slathered enough on each plug to make the OUTSIDE of the plug less resistive then the center conductor and gap... wink
jgavac
Nov 3, 2011 09:27 PM
PEG
1997 - 2003 F150
Feb 25, 2011 01:04 PM
Kijutsu
1997 - 2003 F150
Apr 6, 2009 07:27 PM
DickyBoy
May 3, 2006 06:10 AM
4.9LFord
Feb 2, 2005 07:22 PM
