1978 - 1996 Big Bronco
question about rearend
Old May 6, 2002 | 12:02 AM
honney's Avatar
honney
>The rear sensor yall are talkin about is not the ABS sensor.
> The sensor you are talkin about happens to be the VSS
>(vehicle speed sensor0
Well, I'd love to hear about your custom setup, it would be good tech info and should go on an FAQ page somewhere. But you're a bit unclear on model year differences. Up thru '92 the VSS is on the t-case, the sensor in the rear end is for the RABS (rear ABS) only. The speedo and odometer couldn't care less about the diff-mounted sensor '87-92. '93 up, if deprived of the diff-mounted sensor, will lose speedo, odo, and shift poorly (which is where your custom setup comes in). FWIW.
Old May 6, 2002 | 05:31 PM
chulsey12's Avatar
chulsey12
[updated:LAST EDITED ON 06-May-02 AT 06:33 PM (EST)]hey honney, i have a 90 model with the 351, so what do i need to do to make everything work right on mine, the axle i am getting is off of an 86 bronco, thanks for everyone's advice, it is much appreciated
and to rebelford, i would like to get a 9" instead but i am getting both the front and rear axle with 4.56 gears already installed for $250 which is a deal i cant pass up (i think it's a good deal anyway) what do yall think?
Old May 6, 2002 | 09:52 PM
honney's Avatar
honney
Seriously, here's what you need to do: forget about the RABS sensor, tie the plug/harness up out of the way. Remove the ABS lite from the dash. Never think about it again. This will work 'cause you have a '90 and RABS is worthless. Your VSS is on the rear of your BW1356 t-case. Everything else should work fine (odo, speedo, E4OD, cruise).
I think it's a deal.
Old May 6, 2002 | 10:41 PM
rebelford's Avatar
rebelford
Hey Chulsey, i got your e-mail but it wont let me respond to ya. Whats your e-mail address again?
Old May 7, 2002 | 07:20 PM
chulsey12's Avatar
chulsey12
oh it has changed, sorry about that, it is clint.hulsey@verizon.net
terrylamar
Jul 20, 2016 07:55 PM
taylorbickett5
Sep 16, 2014 03:44 PM
Classic Hauler
Flathead V8 & Flathead 6
Jul 20, 2010 02:27 AM
ratocchio1
Apr 15, 2010 03:56 PM
SVTYONE
Apr 27, 2004 07:40 PM
