should i take this or find something different?
09-15-2014, 09:23 PM
on
I am currently in search for a rearend for my 79 f150. for now i just want something to put in so i can drive it. i found an 82 LTD with a 8.8 rearend. would this be a decent rearend to use? and does it have the same bolt pattern as an f150? thanks guys
09-15-2014, 09:40 PM
If you can't find a ford 9" or just want the 8.8 then you'll need one from an F150 or bronco for a simple swap.
The car axle has a different wheel lug pattern just to start off with. Too many differences IMO.
09-15-2014, 09:53 PM
on
alright thats the answer i was looking for! thank you. do you know if they changed the setup in the 80's pickups? i know of an 86 with a 9 inch. just dont know if its a straight swap
09-15-2014, 10:01 PM
Should bolt right in, Spring perches are the same width im 95% sure. May run it some differences in yoke/ujoint sizes.
09-15-2014, 10:06 PM
on
Quote:
Originally Posted by
ShaneNP123
is that simple to work around? what would be involved there?
09-15-2014, 11:04 PM
I think most 9" axles have a standard yoke. If you get a 8.8 with a flange style mount then you'll need the flange from the d-shaft too.
I'm not positive, but it should be a typical 1330 series u-joint for both axles...I have seen 1310's though on the 9".
09-16-2014, 12:12 AM
on
i will just probably be patient and try to find a rear axle from my year range that matches my front axle. not sure what my front axle is though.
Until i can get to the pickup to find out whats for surely in it, what were the popular front axles that were used in a 79 f150 lariat 4x4 with an np205 t case and a 9" rearend?
09-16-2014, 03:31 AM
8.8" introduced in 1983 F100/150 & Bronco, but the 9" was also available thru 1986.
Some 1980/83 F100's have 5 lug 5.50" bolt circle wheels, some have 5 lug 4.50" bolt circle wheels.
You cannot use a Passenger Car rear axle in a truck.
09-16-2014, 06:16 AM
on
your front axle should be a dana 44. i would be patient and find a good 9 inch. the 8.8 doesn't seem to have the strength the 9 inch does.
09-16-2014, 09:46 AM
on
NumberDummy
Thanks NumberDummy! quick question, all ford 9" rear ends have the carrier built into the cover that is facing the front of the vehicle right?
09-16-2014, 12:57 PM
taylorbickett5
Yes, But so did 8" Fords. But I believe they were only installed in cars.
09-16-2014, 02:39 PM
on
09-16-2014, 03:44 PM
Apo stolic
11-04-2018 04:12 PM
deljac
12-17-2014 06:46 PM
Bovaloe
04-27-2011 05:19 PM
nolan62
46
07-23-2010 09:16 AM
Greywolf
11-18-2001 04:58 PM
