Differential
Old Apr 23, 2004 | 10:32 AM
SVTYONE's Avatar
SVTYONE
Unhappy Differential
I Was Wondering If Anyone Knew What Size Rearend My 1971 F250 Camper Special WITH A 390V8 Has.the Truck Is A Manuelwith Grannygear.also If I Change My Rearend Gears Will This Affect The Power Of My Granny Gear. Open To All Suggestions.
Old Apr 23, 2004 | 06:29 PM
mark a.'s Avatar
mark a.
It's a Dana 60. Yes it will affect it, but it probably wont be very noticable if you don't stray too far from the origanal ratio.
Old Apr 24, 2004 | 04:42 PM
fordbeast_80's Avatar
fordbeast_80
Well it depends on what you want to change your gears to? and if your rearend has a tag on it if you put the numbers on here someone could help decode it.
Old Apr 26, 2004 | 10:26 AM
SVTYONE's Avatar
SVTYONE
Thumbs up Thanks
THIS INFORMATION IS HANDY. WOULD YOU HAPPEN TO KNOW WHAT THE GEAR RATIOS ARE STOCK AND ARE 3.73 TO MUCH.I NEEDED THE DIFF SIZE SO I CAN BUY AN AIR LOCKER OR PRICE A POSI-TRAC.
THANK YOU
Old Apr 26, 2004 | 03:13 PM
Torque1st's Avatar
Torque1st
Posting Legend
Please don't post in all caps. Get the numbers off the diff you have and post them here. There was no "stock" ratio. You can also get those numbers off of your diff and call the companies that sell axle parts.
Old Apr 27, 2004 | 07:40 PM
Like M. Fords's Avatar
Like M. Fords
Unless you change the rear ratio drastically, you won't notice much difference in granny gear. It is the engine RPM at hiway speeds that will have the biggest/most noticeable effect on a rear gear change.
my 66
Feb 5, 2014 05:45 PM
briank
Jun 22, 2011 10:14 PM
Alter Ego
26
Mar 22, 2009 10:42 AM
BeSee
Mar 24, 2004 09:51 AM
heep70
Jun 19, 2003 12:37 PM
