What is the rev limiter on the 5.4l and the 4.6l.?.? Just wondering incase i decide to mess with the shift points...Kinda funny that we dont have a red line... or at least not before 6k rpm... i know the engines are rev happy but dang... thats a bit high aint it?
I really had issues with the my Superchips tuner. I went with their recommended SC default performance tune and eliminated the rev limiter, shifted real nice and firm but the shift points were set way too high rpms for my liking. I find these engines tend to lose their steam at about 4500 rpms and the power dies off. I found by setting the 1-2 gear shifts points worked the best when it was one or two notches more from the stock setting, everthing else was to the SC default settings except shift pressure which I maxed out every gear.
Where did you put your 1-2 shift point at? Im afraid to max out my shift pressure.... Dont you think it might tear somthing up... im all for it just dont know how far to go?
The 12" torque converters that are in these transmissions will baloon and cause all kinds of serious damage if revved over 5400 rpms. The intake manifolds are extremely restrictive to make low-end torque,and will not be able to deliver enough air to rev much past 5000 rpms.
JL
5000 max is a good place to stop. The 5.4L has a very long stroke 4.17". I run all of my tranny pressures turned all of the way up with no torque modulation. It doesn't hurt anything. Just firms up the shifts some and eliminates slippage between gears. No slippage means less clutch wear.
I wouldn't rev a 5.4 over 5400 rpm. I tried it with my truck & I actually run 3 tenths faster shifting at 5200 than I do shifting at 5800 rpm. You can feel the power drop off after 5200 rpms in my truck.
I'm not too sure how the an Edge tuner works, but my Superchip tuner has a min, stock, and max setting with about four dots in between them for the shift points, the same being for the shift firmness settings also. I found that only the 1-2 gears will run into over revving problems, and I just increased 2 dots up from the STOCK setting. Everything else was maxed out, it took me quite a bit of messing around to find what worked for me and my driving style, but I will say this, I never goes past 4800 rpms +/- 100 before it shifts into second gear, that way it shifts right at the peak of the Hp + Torque curves which in turn allows for maximum acceleration.
changeing all of this bumping shift firmness and pressures up from stock , will it hurt anything or are these tuners built with a failsafe not to go over the excepted limits, ive messed around with the superchip as well and it really changes things a bit, But ive never read or heard of anyone tearing anything up due to installing a tuner of any
kind, Im planning on running the towing features and trying the higher octane tune for the bigger tires i just installed..Im sure it will take some tinkering...
I used the Hypertech and like the simplicity....it asks you how many RPMS you want to increase, i increased the 1-2 and 2-3 shifts by 300 RPMs and changed the redline by 400 RPMS....as recommended by Hypertech.
It all depends on who's configuring the software on the tuner.
JL
I guess I should have been more specific, I was talking about tuners you buy off the shelf or "canned" tunes. A custom tune can be a whole new ball game, but usually the person has done pretty extensive mods to their vehicles.
