Testing The Iac?
Old Mar 20, 2007 | 11:14 PM
cadriver's Avatar
cadriver
Question Testing The Iac?
I took the IAC off the truck and cleaned well with solvent nice and shiny,
then I noticed the small plunge wasn't completely close all the way, so I gave the solenoid 12v and I could hear the solenoid doing a CLICK! CLICK! sound, but the plunge didn't move at all?
Is the valve bad?
Old Mar 20, 2007 | 11:35 PM
Benaghetto's Avatar
Benaghetto
It maybe stuck. I know of no way to test. Have you noticed it having a little trouble idling after startup? Expecially when cold?
Old Mar 20, 2007 | 11:43 PM
cadriver's Avatar
cadriver
Originally Posted by Benaghetto
It maybe stuck. I know of no way to test. Have you noticed it having a little trouble idling after startup? Especially when cold?
NO I don't have that exact problem, my truck starts wonderful, after warm up it shakes a bit too much at idle, not like is gonna stall but shakes a bit,
maybe I'm convinced that it should be quiet and smooth like a Cadillac!
Old Mar 20, 2007 | 11:51 PM
Benaghetto's Avatar
Benaghetto
The IAC is basically an electronic choke for an F.I. engine. A small amount of shaking isn't to much of a cause for worry. But when it gets violent is when there's something that obviously needs fixin.
Old Mar 21, 2007 | 12:03 AM
cadriver's Avatar
cadriver
I have a really bad rack & pinion leak, I don't know if it can cause the shaking
cuz of missing pressure at the pump?
Old Mar 21, 2007 | 06:20 AM
JeremyJ's Avatar
JeremyJ
i think you mean a lexus or an acura, crapillac = GM = Garbage.
Old Mar 21, 2007 | 09:02 AM
elite64a's Avatar
elite64a
Ok I know this sounds stupid but I keep hearing IAC this and IAC that but I cannot figure what that is an acronym for. So what does IAC mean?
Old Mar 21, 2007 | 09:34 AM
rubydist's Avatar
rubydist
IAC = idle air control valve. It controls the amount of air bypassing the throttle plate at idle to control idle speed.
If the iac is bad, the truck will idle too fast when you come up to a stoplight when its warm. Or, it will die because of idling too slow. The iac will not cause/correct rough idle.
The shaking at idle is more likely a plug or wire or injector issue than iac. The engine won't care about the leaking rack, but the rack does, so I'd recommend getting it fixed.
Old Mar 21, 2007 | 10:39 AM
elite64a's Avatar
elite64a
Wink
Thanks for the info
MonsterTruck\m/
1966 - 1977 Early Broncos
Nov 3, 2011 06:00 AM
Rcmgiasson
21
Mar 17, 2011 07:57 PM
BigSouth
Feb 15, 2011 03:34 PM
f150plow
Dec 3, 2006 05:39 PM
canuck12ca
Garage & Workshop
Aug 17, 2005 05:52 PM
