1978 - 1996 Big Bronco
Gasoline Question
Old May 26, 2002 | 08:20 PM
alpine7572's Avatar
alpine7572
Gasoline Question
Hey All,
I have a 96 XLT and I use premium in all my cars. My friend told me that in american V8's they love Regular b/c premium leaves carbon deposits on american V8's.
Is this true?
What Gas do you use?
Old May 26, 2002 | 10:02 PM
AlM's Avatar
AlM
Gasoline Question
yo Alpine,
We have a 96 Bronco 5.0 and use 87 octane with good results (15 mpg overall). Once used prem. when fav station was out of reg 87 and CEL lit off (gas cap was tight btw). Ford tech said this sometime happens when using Prem. Does your CEL ever light off?
Old May 27, 2002 | 11:20 AM
djbaines's Avatar
djbaines
Gasoline Question
If you're not experiencing preignition (spark knock, pinging) with 87 octane gas, for example, then you don't need to run a higher octane gas.
I know that you'll hear people say that their car runs better, or it's more responsive, or what have you, with a higher octane fuel. From an engineering point of view, octane is an ignition retardant, and nothing more.
They need octane in gas because unlike diesel fuel, gasoline is more volatile, and octane is decent way to control the volatility as the pressure and temperature rise in the combustion chamber. When your car is pinging, the air/fuel mixture is igniting before the spark plug fires. Then the spark plug fires, and as the two flame fronts advance across the top of the piston, they collide. The noise you hear is from the piston slapping against one side of the cylinder from this force. Usually, engines with bad spark knock are on their way out.
Hope this helps.
Dan
Old May 28, 2002 | 10:56 AM
jimandmandy's Avatar
jimandmandy
Post Gasoline Question
Carbon deposits due to premium, thats a new one. Anyway, even the oil companies will admit, when pushed, that a higher octane than required in the owners manual is just a waste of money. Chevron used to put more detergent in the premium grade, but not any more.
Some engine designs will accumulate more carbon than others. The 2.9 in my old ranger needed a shot of Techron annually to stop pinging.
Jim
Old May 28, 2002 | 09:15 PM
Organdonor's Avatar
Organdonor
Gasoline Question
now I have a chip (hyperchip. do I need to run higher octane?
Thanks
Old May 29, 2002 | 09:55 PM
cyberdr2's Avatar
cyberdr2
Gasoline Question
I use to run high octane fuel in my cars as well (mostly imports). But with my 93 Bronco 5.8L I found no advantage. In fact I found that running the higher octane I got 10-11 miles to the gallon in the city. Running 87 octane I got 13-14 in the city. Consumer reports did an article on this a while back and confirmed that using a higher octane than recommended in your owners manual has no long term advantage.
Old May 30, 2002 | 03:49 PM
seebeew's Avatar
seebeew
Gasoline Question
Old May 31, 2002 | 08:18 PM
alpine7572's Avatar
alpine7572
Gasoline Question
Thanks for your help!!
I haven't felt a difference or experienced any problems yet. But so far, Regular works fine.
Mike
demery
Dec 28, 2017 08:48 AM
ALL AMERICAN BOY
20
Feb 28, 2012 12:23 AM
ford2000ex
Dec 29, 2010 11:59 AM
shammoofressh
2009 - 2014 F150
May 11, 2009 10:03 PM
