I should be getting an 86 Bronco pretty soon and I am wondering about some of the specs. I know it is totally stock with a 351 and a manual tranny. Can anybody tell me a little about this vehicle. HP torque etc... Thanks Alot...
I wonder what a Flowmaster sounds like on a 5.0????
Check out:
The '86 351-4V H.O. engine was rated at 210(net) horsepower@3,800rpm& 315 lb.-ft. of torque@2,800rpm.You asked how a set of Flowmasters would sound with a 5.0L(302) engine.....I have a '90 with the EFI302,and it has duals with Flowmaster 50-Series mufflers.It sounds great!
The Bronco comes standard with a HO 351? Nice... I assume that there is many ways to mod this motor also. I can't wait to start. Thanks
-Chris
Check out:
[a href="http://www.seebeew.8m.com/exhaust" target=new]www.seebeew.8m.com/exhaust[/a]
to hear that and more!!!
A 4-Wheel&Off-Road comparision test in their September 1982 issue included a Bronco fitted with a 351-2V backed by a wide-ratio 4-speed manual overdrive tranny.It's ratios were-3.01 first,1.78 second, 1.00 third,and 0.72 fourth.
>Boy, I'd love to hear more about this Bronco 'cause I've
>never seen a manual behind the 351 from the factory.
When I bring it home I will tell ya all about it...
Check out:
.72 fourth? What tranny is that? Can you get me a copy of the article?
That article was a reprint that is included in Brooklands Books "Ford Bronco 1978-1988".If you'd like a copy email me with your mailing address,and I'll mail you a copy.If you don't want to do that,I've seen a few copies of this book on ebay.I don't know if it is still in print,or not.
