Sponsored by: Kumho
steering help
Old Mar 18, 2007 | 10:13 PM
KSTTAC's Avatar
KSTTAC
steering help
have an 89 f250 2wd steering seems loose. doesnt bang around or rattle just when driving down the road seems to wander left to right a little. it that the steering box....if so how much will that set me back....is it hard to replace? im somewhat mechanically inclined....help
Old Mar 20, 2007 | 01:49 PM
jtmerritt's Avatar
jtmerritt
Have you checked all of the front end parts, ie., tie rods, ball joints, pittman arm, etc, to make sure they aren't worn excessively? Also, check the connetion between the steering gear and the steering shaft. Even slight wear at this joint is magnified at the stering wheel. If everything else is tight, you might try adjusting the steering gear preload on top of the gear. There is a lock nut and allen screw to allow for adjustment. Mark the location of the screw and nut before you start. I spray the area with brake parts cleaner and then use some touch up paint to mark. Then while holding the allen set screw loosen the lock nut about a hal turn CCW. While holding the lock nut turn the allen set screw CW about an 1/8 of a turn and then check the steering. Continue to do this until the steering feels right but do not overtighten the allen screw or you can cause bearing failure in the steering gear. You should maintain about an inch of play in the steering wheel.
John
Old Mar 20, 2007 | 06:15 PM
KSTTAC's Avatar
KSTTAC
ill try that....all the other looks ok
v10Excursion04
Mar 16, 2014 12:36 PM
BigBlue92
Sep 6, 2011 10:34 PM
bigk_54
Apr 7, 2010 02:02 PM
deadeyedevon
1978 - 1996 Big Bronco
15
Jan 4, 2010 06:12 PM
moonley
24
Apr 8, 2005 12:35 PM
