Broken Tach.
Old Mar 11, 2007 | 07:24 PM
B-Bob's Avatar
B-Bob
Broken Tach.
The tachometer on my '87 6.9L isn't working. Is it hard to fix? Where should I look first for the problem? Thanks
Old Mar 11, 2007 | 09:31 PM
Dave Sponaugle's Avatar
Dave Sponaugle
B-Bob,
Welcome to FTE and the IDI diesel forum.
My first guess would be the tach sending unit.
Here is a picture with it and the wire connection labled.
Old Mar 12, 2007 | 08:18 PM
B-Bob's Avatar
B-Bob
Thanks. Are they expensive to replace?
Old Mar 14, 2007 | 08:36 PM
Dave Sponaugle
About 50 dollars at Ford.
Old Mar 18, 2007 | 03:42 PM
dwkremer's Avatar
dwkremer
When my tack stopped I replaced the sending unit, no help. I then started trying to trace the wire (pulling and moving the wiring harness) and I got a flutter out of the tack. With a little more pulling it started to work fine. I'm sure ists some contact, probably ground but it hasen't missed beat in over 50,000 miles so I'm not searching for it.
Old Mar 18, 2007 | 04:37 PM
B-Bob's Avatar
B-Bob
ok, thanks I'll check that out too.
