code help..
Old Mar 15, 2007 | 06:30 PM
mik369's Avatar
mik369
code help..
Hey guys need a little help. 2005 f-150 5.4.. Truck has been fine ,but today starting running really rough. After getting home shut it off used the edge's diagnostic feature and it pulled an 061 and said unknown.anyone have any idea what this is? Thanks in advance ... Mike.
Old Mar 15, 2007 | 07:19 PM
ReAX's Avatar
ReAX
That's not a valid code, how did you get it? If your using a decent reader, your codes will start with a P, B, C, or U. Then followed by 4 numbers.
http://www.obd-codes.com/trouble_codes/
Old Mar 15, 2007 | 07:22 PM
mik369's Avatar
mik369
Hi I didn't use a scan tool I used the diagnostic option that is in the edge programmer after I posted I went out to recheck amd it said p061 unknown ..Seems weird to me to..
Old Mar 15, 2007 | 08:10 PM
ReAX's Avatar
ReAX
Your still short a number. It is a powertrain code though.
Old Mar 15, 2007 | 09:56 PM
mik369's Avatar
mik369
Reax.. I checked it twice and it was p061. Maybe just a fluke in programmer?
Old Mar 15, 2007 | 10:11 PM
ReAX's Avatar
ReAX
well there is no p0610 or P0061
DTC Codes - P0600-P0699 – Computer Output Circuit
* P0600 Serial Communication Link Malfunction
* P0601 Internal Control Module Memory Check Sum Error
* P0602 Control Module Programming Error
* P0603 Internal Control Module Keep Alive Memory (KAM) Error
* P0604 Internal Control Module Random Access Memory (RAM) Error
* P0605 Internal Control Module Read Only Memory (ROM) Error
* P0606 PCM Processor Fault
* P0608 Control Module VSS Output "A’ Malfunction
* P0609 Control Module VSS Output "B" Malfunction
* P0620 Generator Control Circuit Malfunction
* P0621 Generator Lamp "L" Control Circuit Malfunction
* P0622 Generator Field "F" Control Circuit Malfunction
* P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
* P0654 Engine RPM Output Circuit Malfunction
* P0655 Engine Hot Lamp Output Control Circuit Malfunction
* P0656 Fuel Level Output Circuit Malfunction
Your going to need to try another reader. Here's the codes http://www.obd-codes.com/trouble_codes/
Old Mar 16, 2007 | 05:49 AM
mik369's Avatar
mik369
Reax, Thanks for the help I think it was a fluke, We did have alot of rain yesterday I think a coil pack or something got wet.. I'm going to clear the code this morning cause the roughness went away and drive it to work.. I'll see what happens. Mike.
Old Mar 18, 2007 | 12:12 PM
Rangerboy_88's Avatar
Rangerboy_88
no no your right.. i installed a air raid cold air intake on my 04 5.4 an it set codes in it an they were the oxygen sensor an mass air flow if i remember right...an they were p171 an p174
Old Mar 18, 2007 | 01:16 PM
Wilber15's Avatar
Wilber15
Yea, it problably was an oiled filter right? The filter got over oiled i'm betting. Thus contaminating the MAF, and that intern caused the O2 sensor to set a lean code?
SGnAZ
Arizona Chapter
May 19, 2016 03:45 PM
iwanaflattie
Jul 17, 2012 09:14 PM
Ratsmoker
May 26, 2002 06:23 PM
jowilker
Jun 1, 2001 09:41 AM
hillbillyk
13
Jan 22, 2001 11:54 PM
