Aftermarket Products
Sponsored by: Worksport
Performance mods worth getting?
Old Mar 15, 2007 | 02:15 PM
TheTowingCowboy's Avatar
TheTowingCowboy
I'm planning on buying a Edelbrock cat-back exhaust kit, a K&N fuel injection performance kit, and trying to find a computer tuner (Does anyone know where I can find one.) But I'm doing this to my 1995 F-150 Eddie Bauer (302). Plus I heard the Torq rating for Eddie Bauers w/ 302's is 412 Ft. Lb. of Torq. Is that true?
Thanks in advance JP.
Old Mar 15, 2007 | 07:00 PM
ReAX's Avatar
ReAX
Your on the right track, imagine your engine is an air pump. The more air you can get in and out, the more power you can make. Eventually, you will get to the point of needing more fuel too, so as you move more air be prepared to add more fuel. Don't get discouraged, because you will be boosting the effeciency of the motor, so you mileage will not change much.
Superchips might have a tuner for you, but Sniper has a tuner that will cover your application. You have a EEC-IV computer, sence your truck isn't OBD2 your tuner options are a little limited. Check out Sniper, I am tickled pink with my special forces software.
Old Mar 16, 2007 | 10:11 AM
TheTowingCowboy
But I'm still wondering if it's true that my truck cranks out 412 Ft. Lb. Torq. Ok I'll look into the Sniper Tuner.
Old Mar 19, 2007 | 06:33 PM
ReAX's Avatar
ReAX
I don't think so. Only the 302 crate motors are approaching that mark, so unless the motor was swapped, stock should be closer 350-375 ft-lbs.
Old Mar 20, 2007 | 12:14 PM
TheTowingCowboy
Well thats still a good chunk of tourqe. But they said at the page for eddie bauer trucks (1995) that it was cranking out 412, but I don't care as long as there is more tourqe than horsepower.
Thanks for the info.
Old Mar 21, 2007 | 11:50 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
You're thinking of the 7.3L diesel, as they were rated for 210HP and 425ft-lbs of torque.
The 1995 302ci is rated for 185HP and 270-275ft-lbs of torque
Old Mar 29, 2007 | 05:22 PM
Drew2010's Avatar
Drew2010
umm no you and i wish. your making about 280-310 ftlbs of torque.!
natew
Jan 26, 2020 09:14 PM
skytower31
Aug 12, 2009 05:25 PM
motomom05
Nov 20, 2006 01:29 PM
jigs-n-fixtures
1978 - 1996 Big Bronco
Oct 8, 2004 11:26 AM
explorer88
Aug 2, 2003 04:23 PM
