What would be a good winch for my truck.i got a 77 150 carry about 50 gallons of diesel for the tractor in a tank ,a toolbox with some wrenches.id say about 900 pounds for the tools and diesel tank if it matters.My old one broke.
Warn seems to be a premium winch, they also make a discount line called either tabor or magnum. I have a real Warn and could not be happier with it, but I don't use it much. Superwinch, ramsey and milemarker are decent choices, but I am more comfortable with warn for support issues. Your truck should be around the 6K range, so the smallest winch I would recommend is a 9k. If you use a winch often, 12k might be a better choice. A M1200 or XP9000 is where you should start in compairing anyother brands.
ok question i have a 89 f150 and want a winch whats better gear driven or screw deiven
i dount go 4x4-whelling much but if i go and get stuck what would i want???
I haven't see a screw driven one. You want a good quality, planetary geared winch. The planetery is where some companies go wrong, they use either cheap parts or too few satilites.
I also run a Warn winch(15,000) on my F250 but I'm sure any brand will do just as fine. From what i understand a good rule to go off of as far as winch size is 1 1/2 times the weight of the truck. So if your truck is around 6000 a 9000 should work fine. I have yet to use mine to get me out it seems I'm always the rescue truck. Hope this helps
i am a fan of milemarker winches. they are cheaper than warn an friends say they last longer and are more reliable. with warn i think you pay for the name a little too much.
