Modular V10 (6.8l)
Is V10 right choice?
Old Mar 16, 2007 | 11:14 AM
  #31
wfof250v10's Avatar
wfof250v10
The V10 does great towing my 5th ....9,200lbs. I had to switch from the 3.73 to 4.30 gears. Has the HP and TQ to pull it over the sierras at 8,000 ft. I saved 6K not buying the SD 6.0. and the oil changes are a lot cheaper too....!
Old Mar 16, 2007 | 11:26 AM
  #32
azdrawdy's Avatar
azdrawdy
I track every single fill-up.
Originally Posted by Ace!
Yes, please do. Do you hand calculate it? The reason I ask is I was seeing consistently poor mileage and after putting a canopy on my truck the mileage went down another .5mpg or so. I was frustrated at 9.7 or so mpg so I started hand calculating it and realized when the computer said 9.7 I was in fact getting 11.1; so, more than 10% better than the computer said. However, when the computer said I got 12.2 mpg, it was dead on accurate. I don't know why the computer can be that far off sometimes and not others, but I've come to realize I can't assume because the computer is dead on accurate to a 10th of a mpg sometimes that it's not off by at least 10% other times.
I don't use the truck's computer for gas mileage, unless I want to get a good chuckle and hit reset while coasting down a hill. Nothing like seeing 42mpg! It is great for distance-to-empty, but that's it.
I use Ownersite.com. I started with the first tank, at fourteen miles on the clock. I input each and every tank fill-up: Date, mileage, cost and amount of fuel.
On my 2006 SD, for example, Ownersite shows that I have used 940.267 gallons over 55 fill-ups at a cost $2253.81, with an overall mpg of 10.89. My low mpg was 7.72, my highest has been 12.98mpg. My last fill-up on 13 March has not yet been used so it cannot be used to calculate mpg.
Michael
Old Mar 29, 2007 | 05:45 PM
  #33
someday's Avatar
someday
stay away from cv67cheng...i think he is trying to rip me off
Old Mar 29, 2007 | 07:34 PM
  #34
97F250XLT's Avatar
97F250XLT
Go with the V10 good motor pulls well get tow command system with brakes and mirrors Ford is the best setup for towing.
Old Mar 30, 2007 | 05:50 AM
  #35
cv67cheng's Avatar
cv67cheng
Someday,
Who are you? What are you talking about, I've NEVER talked to you! Your post is way out of line!
Old Mar 30, 2007 | 06:10 AM
  #36
someday's Avatar
someday
yeah i realized that i had u confused with someone else and asked the moderator to delete my post...sorry about confusion
Old Mar 30, 2007 | 07:42 AM
  #37
dkf's Avatar
dkf
someday,
You can delete your own posts you do not have to have a moderator do it. Click the EDIT tab in the post and delete the words.
Old Mar 30, 2007 | 07:57 AM
  #38
cv67cheng's Avatar
cv67cheng
Someday,
No problem. thanks for the PM explaining.
PrinceValium
Oct 12, 2016 10:33 PM
O. hemionus
All Things Towing
Jul 28, 2016 02:17 PM
roKWiz
Large Truck
Sep 6, 2015 04:39 PM
roosterjd
Modular V8 (4.6L, 5.4L)
Oct 3, 2014 06:01 AM
