Sponsored by: Auxito
Tranny fluid leak?
Old Mar 13, 2007 | 08:52 PM
buymore's Avatar
buymore
Tranny fluid leak?
I just noticed a reddish colored spot under my 99 F150. When I crawled under it tonight, I saw an oily spot all around the rubber plug in the bell housing. I haven't noticed any performance issues yet and the fluid level is still ok, but on the low end. Is this a problem, is is it normal for a truck with just 57000 miles? I can honestly say I never noticed any leaks prior to this, but I wasn't specifically looking either. It's not as obvious as some would think when you have a gravel drive. I removed the plug and nothing dripped out then either. I was pulling a heavier load two weeks ago on my trailer, could I have damaged something then? What do I need to check? Thanks
Old Mar 13, 2007 | 09:09 PM
Ultramagdan's Avatar
Ultramagdan
No, you haven't damaged anything. Have you changed the tranny fluid though in the past?
Old Mar 14, 2007 | 03:38 PM
buymore's Avatar
buymore
I haven't changed the fluid yet. I bought this truck in 05' with 28000 miles on it. I know for a fact that the previous owner did ALL scheduled maintenance through the dealer as per the manuel. I'll have to check and see if he had that done yet? Is this a sign that my filter is dirty? I feel comfortable doing that myself, so maybe it's time?
I've pulled a heavy load before, but this is the first time I noticed the spot afterwards. I was pulling a trailer with probably 4500#'s or more on it added to the weight of the trailer. The trailer weighs in at 1600#'s empty on it's own.
Old Mar 14, 2007 | 05:14 PM
Ultramagdan
I would go ahead and change fluid and filter. It is not a sign you need to change but now would be a good time if it hasn't. I would try that first.
1995Bronco351
1978 - 1996 Big Bronco
Apr 13, 2013 10:42 AM
mrshark
2004 - 2008 F150
Mar 21, 2012 03:43 PM
02-7.3D
24
Jan 10, 2011 05:51 AM
beefmalone
Jan 9, 2011 02:41 PM
ecs
Apr 26, 2010 12:04 PM
