Sponsored by: Auxito
hesitating and chugging
Old Mar 12, 2007 | 10:51 PM
knschoenborn's Avatar
knschoenborn
My 2000 f150 v6 5sp manual was hesitating (or chugging) when I would idol or put on the gas. I replaced the air filter and it got better. I replaced the spark plugs the same week and it got close to normal but has steadily deteriorated over the last month back to the original condition or worse. It hesitates in low gears and when I put on the gas but is not as noticeable at higher speeds.
Any ideas?
Old Mar 13, 2007 | 11:05 AM
bokker's Avatar
bokker
hi, search the 4,2 forum and you will probably see spark plug wires are critical and new ones may make all the diference. i used BrianA s advice on the make/type but cannot remember which they were. good luck bokker.
Old Feb 1, 2008 | 04:16 PM
grampygreen's Avatar
grampygreen
Question Grampygreen, new member
I have a 2000 F150 4.2 auto which is doing the same thing, we have replaced the wires,plugs,power module and upper and lower pickups. Did you check spark as you give it fuel becauce mine drops off for a milasecond then comes back as it reaches a higher speed. I'm at a loss on this one. need help
Old Feb 1, 2008 | 05:23 PM
ididntdoit99's Avatar
ididntdoit99
did you try clean the maf?
Old Feb 1, 2008 | 08:08 PM
tampa898's Avatar
tampa898
Could be the coil pack too.
Old Feb 2, 2008 | 11:05 AM
grampygreen
we cleaned maf and going to swap out coil pack on monday any other ideas because the only code we get now is trans code no engine codes
Old Feb 14, 2008 | 11:46 AM
grampygreen
hesitation and chugging
I had the same problem with my 2000 F150 4.2 did you check fuses try #23
(15A) under hood on drivers side fender. That's was my problem, good luck
mikerans
Bronco II
Nov 17, 2012 09:31 AM
madcatter33
Dec 24, 2011 11:36 AM
High_Horse
Nov 17, 2011 03:42 PM
amdriven2liv
Jun 2, 2010 09:46 PM
JRCF
Nov 8, 2008 01:10 AM
