chugging, hesitation..
Old Jun 2, 2010 | 06:04 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Ok, coming down from Seattle today on I-5 I was rolling along at 70 manual throttle. Rolled up a little hill, the engine would chug or hesitate. Then on another hill, cruise control on, it did it again. This time when the tranny down shifted to keep rolling at 70, it stopped, (the chugging) and cruised right up over with out missing a beat. ECT 192 EOT 203
EGR opening and closing? Any thoughts?
Hasn't or doesn't do it running around town.
Thanks.
Old Jun 2, 2010 | 06:07 PM
lakewood's Avatar
lakewood
List some more specifics like mods, miles, etc.
Might be the ICP
Old Jun 2, 2010 | 06:11 PM
gearloose1's Avatar
gearloose1
Pull some codes, do an italian tune up and see if it clears issues like carbon and rusting turbo sticking.
Old Jun 2, 2010 | 06:57 PM
amdriven2liv
Might be the ICP
You see them (mods) Miles 35,000 Bugs splattered on windshield. Cleaned egr a couple weeks ago. (yes new gasket kit)
No codes listed. Italian tune up? Last Friday pulled 8800lbs 300 miles from Medford Oregon to Portland, Oregon. 4 passes. Each about 1000 ft. elevation change. No problems. Been "hammering on the throttle" before leaving town last week.
Run Power service diesel clean (grey bottle) every tank. Buy my fuel at mass quantity fuel stop. ( Pilot on I-5 in Central Point Oregon ) Oil changed 500 miles before trip.
checked for water in fuel, none.
Fuel filters changed 6000 miles ago. All OEM filters
ICP was running about 2300-2800 ( highway speeds)
Volts while running down highway 13.9-14.2
Thanks
Old Jun 2, 2010 | 07:31 PM
lakewood's Avatar
lakewood
Sorry i didnt een pay attension to the mods you had listed haha, but what do you mean the Icp was running 2300-2800 down the highway?
Old Jun 2, 2010 | 07:32 PM
bismic's Avatar
bismic
When you cleaned the EGR valve, did you clean the EBP tube and the MAP sensor hose?
Old Jun 2, 2010 | 07:39 PM
amdriven2liv
No I didn't. Is there a link in your spec sheets for this? Will do it!
Old Jun 2, 2010 | 07:47 PM
bismic's Avatar
bismic
There are links to pictures of the sensors and the tube/hose in the spreadsheet. I have them in one of my albums also.
It may be a long shot because it sounds more like a VGT actuator (or turbo) or maybe IPR issue (at least to me), but it is pretty easy to clean them.
Ford Truck Enthusiasts Forums - bismic's Album: EBP and MAP
Old Jun 2, 2010 | 07:52 PM
amdriven2liv
So I pull that tube off and clean it out. My IPR while cruising down the highway was reading between 44% 50%. At idle my IPR sits at 22%
Thanks for your input.
Old Jun 2, 2010 | 09:27 PM
cheezit's Avatar
cheezit
ipr at idle is good. anything under 24% is spec. Icpv should be about .82 or so and idle, over a volt and its bad
just a little note the trucks have some knowen issues with speed contoll and surging going up and down hills. that would be somewhat normal operation.
Old Jun 2, 2010 | 09:39 PM
amdriven2liv
Not sure if or how to measure icpv
Well, that would be kinda the reason when it down shifted, it cleared up. I guess.
Should I still look into clean the MAP tube as suggested? I should anyway just to learn a little more. Don't mind it.
Thanks everyone for the inputs.
Old Jun 2, 2010 | 09:44 PM
cheezit's Avatar
cheezit
IF you can moniter icp voltage that would be icpv. there is a way to do it and it is listed in the 6.0 info/tech folder. I woudl post a link to it but Im not sure were it is as I have never looked in the folder (sorry to admit that).
It would not hert to look at the ebp, ebp tube and map hose. also check the map port in the intake. you may even want to remove and clean the IAT2
next time try it w/o speed controll on to varifiy what I said. I think the speed contoll on the diesel trucks kinda sucks unless your on flat ground.
Old Jun 2, 2010 | 09:46 PM
amdriven2liv
The first time it happened I was manual on the throttle. I'll look into cleaning the IAT2.
Thanks again.
Sean
tr0y
Nov 10, 2014 07:02 AM
mhoefer
Sep 13, 2014 06:05 PM
colieg
Escape & Escape Hybrid
Aug 30, 2014 10:37 AM
JohnnyMantic
Dec 18, 2013 06:27 PM
CalebJns
115
Apr 12, 2011 04:01 PM
