LL#8 and Cylinder Contribution
Got a question for you guys here. A few weeks ago I put on the regulated fuel return on my truck, and I was trying to measure if I need to replace the LL#8 or not. I'm really not hearing any sort of injector cackle or anything like that, but I did do a cylinder contribution test today. I've got over 95K miles on my truck:
Cylinders #1-7 showed 0% - 0.7% change in rotational velocity.
Cylinder #8 showed a 2.3% change in rotational velocity.
I know it's normal for #8 to be off a bit thanks to the LL injector. However I was wanting to know at what % should I look at changing out the injector for a standard AD?
I thought they recommended replacing that LL if you did reg fuel.
I'm not having a cackle issue, but I'd just like to find out if anyone has any exact measurements of what is or is not recommended for cylinder #8 and it's contribution with the LL injector. If I am too high, then I'll go ahead and swap it out. If not, I plan to keep it for now. I just have the feeling that with my PMS, once the valve covers are off, I won't be able to contain myself with only swapping one injector.
cutlass
07-07-2011 04:32 PM
dyhrdford
01-20-2011 02:51 AM
cutlass
37
09-08-2010 07:51 AM
