Window run replacement
Old Mar 12, 2007 | 06:53 AM
75F100GA's Avatar
75F100GA
OK we just about have the 75 ready for the road. Just recovered the seats and new carpet. Close the drivers door last night and hear something fall in the door. Pull the panel and see half of the run laying in the bottom of the door. Plus the window popped off track. Figure I will go ahead and replace both front and back runs on both sides. My question is whats the easy way to get the window back on the track ? And is there any trick or easy way to replacing the runs ?
Old Mar 12, 2007 | 11:59 PM
Twisted Light's Avatar
Twisted Light
I work at a glass shop and the only way to replace the run is to remove the vent window assembly and move the glass forward on its track to give you room to push the new run into place, also leave the top free so you can reinstall the vent window, this works on the front wondows, I've never worked on a four door so the back window are a complete mystery to me???
Hope this helps.
skimtn
13
May 7, 2012 11:23 PM
F-150 LARIAT
1997 - 2003 F150
Feb 1, 2011 02:41 PM
Lobo
Feb 15, 2010 11:41 AM
BroncoBuster
1978 - 1996 Big Bronco
Jun 18, 2005 11:18 PM
rickm5
Aerostar
Sep 19, 2004 11:21 PM
