short tandem axle trailer
Old Mar 10, 2007 | 12:01 PM
Oval_obsessed's Avatar
Oval_obsessed
Is there a point where a tandem axle trailer can be too short? Would 12' be the limit? I thinking that any shorter that the trailer may whip more that a longer trailer.
Old Mar 10, 2007 | 01:40 PM
jroehl's Avatar
jroehl
Tandems, in my experience pull better than single-axle trailers. For them to turn, the tires have to scrub a little, so they're more likely to track straight (provided they track straight in the first place).
Jason
Old Mar 10, 2007 | 04:33 PM
westtntrucker's Avatar
westtntrucker
As in any trailer, how you load it, depends on if it will whip or not. Bigtex trailers make a 10' tandem. Always remember, keep the trailer level when fully loaded. If it dips to the front, adjust the drop/lift in your reciever. same goes for the rear being lower as this is when you most likly to "whip".
Old Mar 10, 2007 | 08:10 PM
cdrmotorsports's Avatar
cdrmotorsports
My dump trailer is 10' long and has a GVW og just under 12.5K lbs. It is a tandem axle, mostly because of the weight capacity. It trailers really well.
Hogtrapper
Dec 20, 2015 01:21 PM
Pedalmasher
Mar 8, 2013 03:06 AM
Timon5435
All Things Towing
Jul 8, 2009 06:42 PM
Mike O.
Apr 9, 2007 09:52 PM
randallc
All Things Towing
Jun 24, 2003 09:00 PM
