ip bad?
Old Mar 10, 2007 | 08:49 AM
jcruth's Avatar
jcruth
Unhappy ip bad?
how do i know for sure if my ip is bad is there a way to test it? 92 7.3idi non turbo.
Old Mar 10, 2007 | 10:09 AM
PLC7.3's Avatar
PLC7.3
Tell us what your IP is doing that makes you think it's bad..... not usually tested professionally .......just rebuilt.
Old Mar 10, 2007 | 10:13 AM
jcruth's Avatar
jcruth
i know i have some air issues but once i get it started(after alot of fightin it) it will only run for 20-30 sece then dies and is a bear to get started again
Old Mar 10, 2007 | 10:14 AM
jcruth's Avatar
jcruth
i should add that it sounds smooth and idles nice while it does run
Old Mar 10, 2007 | 10:21 AM
matts156's Avatar
matts156
Sounds more like air getting into the fuel system.
Old Mar 10, 2007 | 10:26 AM
jcruth's Avatar
jcruth
so my fix is as " simple" as finding the air leak and fixing that??
ive been considering putting compressed air in fuel tank to try and locate air leak..will this cause me any problems as long as i keeep pressure below 15-20 psi??
Old Mar 10, 2007 | 10:31 AM
matts156's Avatar
matts156
I'd think that 15-20 psi would be more than enough to damage your lift pump. I would disconnect the lines and plug the ends then try the compressed air.
Old Mar 10, 2007 | 10:34 AM
jcruth's Avatar
jcruth
ok. i will do that . thx matt.i appreciate your time
Old Mar 10, 2007 | 10:35 AM
roamer37's Avatar
roamer37
This is pretty standard way of checking for leaks but dont go over about 30 to 35 inches of water.... you will blow your tank up..
Old Mar 10, 2007 | 10:40 AM
matts156's Avatar
matts156
Do you know the condition of your return lines or how old the o-rings on the filter assembly are? There are o-rings also in the plastic caps on top of each injector. If any of those are not air-tight, the fuel will bleed back out of the system.
j.g.curry
Jan 22, 2015 06:53 AM
altruego
Mar 2, 2011 04:05 PM
deceptichop
Feb 27, 2011 07:52 AM
rmalottwtes30
Aug 2, 2008 09:02 PM
bignorth
Dec 7, 2006 11:34 PM
